Old 09-25-2013, 01:32 PM
andersonmc andersonmc is offline
Boat: 2001 X star
Taking off rub rail
How hard is it to remove the rail and put back on? Be a lot easier to buff boat out with it off and give me a chance to powdercoat the rail. Planning on putting new rubber in once put back on.
Old 09-25-2013, 01:35 PM
Not terrible, just time consuming. Lots of rivets to drill out.
Old 09-25-2013, 02:12 PM
bochnak bochnak is offline
Boat: 94' Prostar 205 - Indmar 5.7 TBI
Not to hijack, but I have a 3-4" section of rubber rub rail missing. I do have a new section that I will try to cut and install.
Any tips for install? Heat gun & rubber mallet?
-Matt
Old 09-25-2013, 04:19 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
As far as the rail goes, I carefully used a heat gun, and went about every 3-4 feet. Make sure you have someone help you, 50' can be handful. If it is just a small replacement section, like 4', you can manage on your own. On my tristar, as I went along heating 3-4' sections, I would have a friend hold the slack away. Then as I laid it onto the hull, I would insert large silicone covered screws through the rail into the hull, just making sure to follow the body line. My insert was a flexible material that I simply used a flathead screw driver to pop in the rail itself every 2 feet or so. It actually goes pretty smoothly and is relatively easy to do. Once you pull your old rail off......your committed one way or another.
Old 09-25-2013, 09:24 PM
atihanyi atihanyi is offline
Boat: mastercraft prostar 190 1992 w/powerslot
if you are going to remove it do yourself a favor and buy an air rivet gun . Makes it a lot easier to reinstall and have a good place to store it as it will bend very easy . When reinstall the rubber soak it in a five gallon pail of very hot water and use liquid soap to lubricate it to reinstall it
Old 09-26-2013, 10:25 AM
03geetee's Avatar
03geetee 03geetee is offline
Boat: 1983 Skier 190 Stars and Stripes
Removed the old rub rail insert from the boat, that was a snap. Re riveted some bad sections when I have it out on the old rail, then used the hot water trick to soak the entire roll of new insert. Once I started I didn't stop as you are losing heat quickly from the water, but it was not too bad just time consuming and precise.
Can be done!
JTR
1983 MasterCraft Stars and Stripes
Cream/Red Metal Flake
"Powerslot"
"The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish."
-Charles Chaplin-
