Old 09-18-2013, 10:56 PM
packman312 packman312 is offline
Boat: 2011 X-25
6.2L illmor fogging?
Had one boat dealer dont fog- not needee. Skipper bud says fog through fuel filter only as to not foul plugs. Make sense?
Packman
Old 09-18-2013, 11:16 PM
no.. will motor be sitting out side or in a fairly insulated garage. If it was me - I would ask how does the internals of the motor stay coated with oil to not corrode in the swings of midwest winter temps and humidity.
Old 09-19-2013, 12:33 AM
Boat: 2011 X-25
Boat will be in insulated garage. Skipper bud said definitely dony fog thru cylinders. Seems like their is alot of variation on this.
Old 09-19-2013, 06:12 AM
CantRepeat's Avatar
Boat: No Boat
Packman
How would fogging through the fuel filter not get oil on the plugs? Besides I don't see how you could put enough oil in the fuel filter while its submerged in fuel in the fuel tank. Or is he saying to fog through the air filter?
The intake on your boat is called a dry intake, IE it has fuel injectors over each cylinder. On these types on systems it is recommended to fog through the spark plug hole.
Tim
Old 09-19-2013, 06:28 AM
BARE5's Avatar
BARE5 BARE5 is offline
Boat: 1995 PROSTAR
Skipper is right in a way. Fog the cylinders using old spark plugs , that way , in their thinking they can get you a new set in the spring. Fog it all. Injectors , cylinders, spray the motor down with a WD-40 type on the external parts. It works. Insulated garage or not, unless your taking all of us out for a ski run in December, there needs to be protection inside the engine too.
Old 09-19-2013, 07:56 AM
jgraham37128
Guest
Posts: n/a
2010 X2 5.7
This was me last year.
Old 09-19-2013, 09:56 AM
CantRepeat's Avatar
Boat: No Boat
Mr Graham is doing it right!
Tim
Old 09-19-2013, 10:07 AM
sand2snow22's Avatar
Boat: Ri257
Actually IIRC the owners manual for Ilmors says to fog through the intake
Old 09-19-2013, 10:26 AM
CantRepeat's Avatar
Boat: No Boat
I looked through the 6.2 owners manual I downloaded from Ilmor before I posted. It has nothing in it about fogging under their winterization procedures.
http://www.ilmor.com/en/marine/recre...s-manuals.aspx
I believe the concept is that it's a dry intake and coating it with heavy oils is not recommended.
Tim
Old 09-19-2013, 11:27 AM
dry intakes no fogging thru intake - fog thru spark plugs - mine fogs like above pic...
