Old 09-14-2013, 07:59 PM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
One came I'm my 93 190 and I think it's a great idea .. Can never to be careful Name:  ImageUploadedByTapatalk1379203156.955655.jpg
Sent from my iPhone using Tapatalk - now Free
Old 09-14-2013, 09:08 PM
2010Prostar197's Avatar
2010Prostar197 2010Prostar197 is offline
Boat: 2010 Prostar 197
I see it's upside down. Does it work well that way? Just curious.
Old 09-14-2013, 09:22 PM
gsxrjtt's Avatar
There is also no motor in the boat from bad winterization when I purchased it. So hence the wrong position from hoses being moved and taken off. was just purely showing older mastercraft boats can fit them..but i have seen them in different angles
Old 09-15-2013, 02:29 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
Noticing some pictures of the newer MC's with seawater strainers. Did a search but only a couple of threads come up.
I read somewhere and can't find he thread that some times these strainer don't seal and an air gap can prevent raw water flow.
I boat in muddy waters with lot's of duck weed.
Something worth while?
Originally Posted by 2010Prostar197 View Post
I assume the strainer you are talking about is the black canister with a clear cover. If that's the one then yes, they do not seal well.
I went to the Sherwood strainer. Skidim along with others carries them
Just my .02 cents worth
Although I seen the couple posts where the person(s) had issues with that strainer, I have to add that I have that strainer and it works just fine for me. It is mounted inside the rear starboard locker (for my v-drive) for easy access. Nice thing about the way it is mounted is that you can open and clean the strainer and you don't loose the water (prime) between it and the raw water pump.
Looking at the Sherwood, it appears to be smaller in size and I think you would have an easier time mounting it in-line or in otherwise smaller access areas.
Just a different worth.
Old 09-16-2013, 11:02 AM
broncotw's Avatar
broncotw broncotw is offline
Boat: 2010 MasterCraft Prostar 190 TT, Indmar MCX GM 350
I also went with the Sherwood strainer on my 93 Stars and Stripes....
There is a ton of duck weeds and debree where I ski.....
It was a really tight fit as you can see in the pics....
Since the install, I have had zero problems....
Ted W
Hook Em' Horns
Old 09-16-2013, 12:50 PM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
I have one on my boat-a nice heavy duty bronze topped one (don't remember the brand off the top of my head). I think they come standard on the saltwater series boats. I always clean mine out at the end of the year, but there hasn't ever been much in it. While winterizing this year I finally discovered the drain-I had been sucking the water out of it with the shop vac previously.
2006 Maristar 200 SS
seawater strainer
