Old 09-14-2013, 08:32 AM
matttillman matttillman is offline
Boat: M/C Prosatar 190, 1990
I hit a log!
We hit a submerged log yesterday. Terrible noise. We shut everything down, made sure we weren't taking on water and started it back up. Motored idled fine but in gear we had a vibration. Limped it back to the ramp and when out of the water there was only minor damage to the prop - not what I expected from the vibration.
Questions - does pretty minor damage (slightly bent blade) cause noticable vibration? After prop repair anything else that needs to be checked out?
Boat is 1990 PS 190. Thanks!
Old 09-14-2013, 08:44 AM
clrussell's Avatar
While your prop is off check your shaft with a dual indicator. I did same thing, same boat actually. But I think I hit something direct because when mine hit I instantly had such a terrible shake you couldn't get it over idle speeds
Old 09-14-2013, 08:46 AM
John 3:16-18
slightly bent prop can throw the prop out of balance... get a dial indicator to check if shaft is true.
hopefully prop took the brunt of it.
Old 09-14-2013, 08:57 AM
Thanks guys! Ill check the shaft when I pull the prop tomorrow.
Old 09-14-2013, 09:04 AM
Sorry, what should my tolerance be?
Old 09-14-2013, 09:17 AM
clrussell's Avatar
I think Tolerance is .003?
Old 09-14-2013, 10:54 AM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
I got some lake weed from the shallows taking boat out end of last season.
Definite vibration. It doesn't take much...
Old 09-14-2013, 02:38 PM
pmikler's Avatar
pmikler pmikler is offline
Boat: 2006 x30
hit a log this year as well. The prop didn't look bent at all at first glance. In short, I had read it doesn't take much but was surprised how little will cause serious vibration.
Old 09-16-2013, 07:32 PM
snork snork is offline
Boat: 07 xstar
I noticed a post a few days back but can find it for the life of me, the post had a new and a used OJ prop I think it was 13.7x17 or something like that $250???
