Old 09-07-2013, 09:26 PM
johnlanguab's Avatar
johnlanguab johnlanguab is offline
Boat: Barefoot 190, 89, Indmar 454
Gremlins, 89 Tristar BB
Alright, after another good year about to close, my boat developed gremlins.
It runs great for about 30-45 minutes. Then, it will just die totally. If I let it sit for a little bit, anywhere from 15 seconds to 4 minutes, it will fire right back. It will run another 5 minutes or so and I repeat the process.
Initially, I thought it was the ignition coil, as it was a little warm. I replaced the coil and it's doing the same thing.
Too, today I noticed gauges and everything die when it cuts off. So, this would rule out ignition, right? I was thinking the coil and EI module were not tied in with the fuel, voltage, oil pressure, or temperature gauge, right?
I'm going to check connections tomorrow. anyone have any suggestions or recommend a place to start?
Old 09-07-2013, 10:37 PM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
Bad ground cable perhaps?
Old 09-08-2013, 08:35 AM
Bump.
Old 09-08-2013, 07:54 PM
Checked and cleaned all ground wires. Cleaned wiring harness, switch wires, main circuit wires. I'm about to move to the wire that runs from the switch to the coil...
It acts like the boat just totally switches off. Then, it's fine a moment later.
Old 09-13-2013, 04:51 PM
If anyone is interested, it was the "on" connection on my ignition switch. It had corroded and was not making good contact.
Old 09-13-2013, 05:03 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
I was interested.....been following along, glad it worked out. Electrical gremlins are the hardest to chase...
Old 09-13-2013, 08:24 PM
drschemel's Avatar
Sorry no one had any good advice for you. I knew it had to be either the ground or the power cable!
Old 09-13-2013, 09:13 PM
I just hate it when people don't post the solution to problems after soliciting the help of the forum.
Old 09-13-2013, 09:22 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
Great to hear you fixed it. That is one to remember.
Old 09-16-2013, 11:06 AM
broncotw's Avatar
broncotw broncotw is offline
Boat: 2010 MasterCraft Prostar 190 TT, Indmar MCX GM 350
Glad you fixed it....
Ted W
Hook Em' Horns
