Old 09-09-2013, 11:53 PM
Ben Ben is offline
Boat: '94 PS205 LT1
I also heard the plastic stuff was pricey. Plus, I live where I need to consider I may have ice packing in on the "roof", if water drips down from the deck. Plus2, I wanted something to do a lot of work once and be done.
Here are pics. As I mentioned, I wanted the boards that the metal roof panels attached to oriented in the direction water flows. So, I used 2x4's, 2x2's etc between the deck joists and hanging down to set up the pitch. You can see each "row" hung further down as it got away from the house.
Next, I screwed long 2x2's to these, resulting in 2x2's the same direction as the joists with proper spacing to screw the roof panels to. You may be able to just screw a 2x4 to the side of a joist at the proper pitch, but I couldn't get the spacing right for screwing the bolts on, and I wanted them spaced equally for looks.
Because the deck cantilevers out over the steel beam (I added that too - went from 6 deck posts to two...), I had to pitch to the beam from both sides. Then had gutters added.
Overall, happy with the job, and the cost was <$500 I think. Deck is about 10x24 or so.
Old 09-10-2013, 02:26 AM
atthelake's Avatar
atthelake atthelake is offline
Boat: 2014, X30, 6.0 Gen2
I think I'm gonna do something similar. I was thinking about using a solid soffet instead of roofing tin. I thought this might cut down on the overall weight. Deck is 16x36.
Old 09-10-2013, 08:29 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: 40th Anniversary X14
That yellow wire shouldn't be used outdoors.
40th Anniversaary X14
Prior boats - 2009 X14, 2008 X14, 2005 197, 1997 Prostar 190, 1988 Tristar 190, 1989 Prostar.
Old 09-10-2013, 09:15 AM
Ironhorse Ironhorse is offline
Boat: 2008 Mastercraft X14 w/ LY6
Great idea! I have been cursing myself for not using duradeck so I can sit underneath. Now I have a new project.
Old 09-10-2013, 09:49 AM
homer12's Avatar
homer12 homer12 is offline
Boat: MC Tristar 190 OB, 1989
That's what I was thinking. Not outdoor approved.
Old 09-10-2013, 10:21 PM
Ryan's Avatar
Ryan Ryan is offline
Boat: 2007 SANTE 220
Here are a few pictures. The pic from the inside looking out shows the only spot that has a slow drip due to the curvature I made. That curve prevents me (6'4") from slicing my head on galvanized metal with a high point of about 6' at the gutter and a low point of 5' near the house. The metal does reflect light pretty well, and doesn't create the creepy cave effect that I thought would spook my kids. They're all comfortable playing in there.
The best advise I can give:
  • Don't try using a sawsall, get a metal blade for your circular saw
  • Don't do this in February like I did when it was sunny but 18 degrees. Leather gloves don't flex much when it's that cold.
