Old 09-03-2013, 05:49 PM
Not sure. I have Dexron III in my boat which calls for Type F trans fluid and mine works just fine.
They all say backwards compatible...
Old 09-03-2013, 05:55 PM
Yeah, but who are "they"?
Old 09-03-2013, 06:03 PM
GM and Ford - GM - Dexron VI good for Dexron III - Dexron III good in Dexron II applications - Castrol applications on Dexron and Mercon.
Old 09-03-2013, 06:12 PM
I know.....
Old 09-03-2013, 06:23 PM
19_Skier's Avatar
19_Skier 19_Skier is offline
Boat: 2001 19Skier
strange that they switched to motor oil not ATF - that tranny definitely calls for ATF.
Can I switch it back or do I stick with motor oil?
Old 09-03-2013, 06:30 PM
John 3:16-18
Old 09-03-2013, 08:59 PM
Boat: 1997 ProStar 205
the old increase the viscosity to hide a problem trick...nice....
I worked at a Honda dealership in the mid 90s. An older car came in on trade that smoked like a chimney, service ship drained the oil, added 90 wt gear oil and sent it off to auction. Little to no smoke while running.
That is why buying at the auction got such a bad name.
1997 PS 205
Old 09-03-2013, 10:52 PM
macattack's Avatar
macattack macattack is offline
Boat: 2005 MasterCraft PS197 TT, #31/100, MCX 5.7L
Attached is the Service Advisory ref the change to 15W40 motor oil...not sure the fluid type really answers your vibration issue at low speeds.
2005 ProStar 197TT, #31/100; Tournament PB 1.5 @ 38 off, June 2012
Old 09-03-2013, 11:46 PM
Boat: 1998 Maristar 200VRS
If you've got 15w-40 in there, that's what I'd refill with after a drain. If you've got ATF and you don't have a rattle problem, that's what I'd refill with. If you've got ATF and a rattle at idle/low speeds that you'd like to get rid of, I'd refill with 15w-40.
Old 09-04-2013, 06:40 AM
19_Skier's Avatar
Boat: 2001 19Skier
Thanks! I see it says V-Drive or In-line so that makes sense why it was changed. I'm not sure it will cure the vibration either but I think changing it is a good place to start, work my way through the more simple things that I am comfortable doing myself first and go from there.
