Old 09-03-2013, 04:14 PM
19_Skier's Avatar
19_Skier 19_Skier is offline
Boat: 2001 19Skier
Did you look in the manual to see what lube is recommended?
yes, calls for pennzoil dexron II/III in the manual. The colour has never been red (2nd full season with the boat) and it's never changed in colour over those 2 years.
Old 09-03-2013, 04:19 PM
Certainly due for a change. Just need someone to chime in if this is one of the transmissions that benefits from using motor oil vs. the designated transmission fluid.
Old 09-03-2013, 04:25 PM
19_Skier's Avatar
Boat: 2001 19Skier
Thanks TMMC! Yeah, I am really confused now as I specifically asked the dealership that does the winterization to check the trans fluid last fall and they told me it was clean and good. From the research I've done seems pretty straight forward to change myself this weekend.
Old 09-03-2013, 04:27 PM
Voodoo's Avatar
Voodoo Voodoo is offline
Boat: '06 MC 197 TT MCX
Check the cutlass bearing. A worn bearing will cause noise/vibrations at slow speeds that become inaudible/less noticeable at speed.
Old 09-03-2013, 05:19 PM
strange that they switched to motor oil not ATF - that tranny definitely calls for ATF.
Old 09-03-2013, 05:26 PM
I believe it was because the trans fluid was thin enough that there was some rattling sounds heard. The oil, being thicker, prevented this.
Old 09-03-2013, 05:36 PM
the old increase the viscosity to hide a problem trick...nice....
Old 09-03-2013, 05:41 PM
I remember putting 20W-50 Valvoline in my old 79 F150 with 160,000 miles on it just to have adequate oil pressure during it's last summer.
Not sure what Hurth was thinking. Transmission fluid is a better lubricant than motor oil. One would think they understood tolerances.......
Old 09-03-2013, 05:45 PM
so then is 100% synth ATF too slippery for our boats? Not to start and oil discussion
Old 09-03-2013, 05:48 PM
Not sure. I have Dexron III in my boat which calls for Type F trans fluid and mine works just fine.
