Old 09-03-2013, 01:41 PM
19_Skier's Avatar
19_Skier 19_Skier is offline
Boat: 2001 19Skier
Vibration in Reverse/Drive
So I have noticed over the last month when I first reverse the boat out from the dock for a cruise or ski it shakes pretty bad. I have also noticed what I can only describe as almost a "chugging" sounds when I put it in forward, only at idle speed. There's no noticeable vibrations or sound at ski speeds (26 - 36 mph), but I have felt a bit of a slip the odd time when first taking off.
These issues seem to disappear after running the boat at temp for 5 - 10 minutes. I check my transmission fluid religiously and it hasn't moved on the stick, I am wondering what else I should be checking?
2001 Prostar 19Skier with the 310 predator, 1:1 transmission and 756 hours.
Old 09-03-2013, 01:43 PM
ATF changed recently as well?
Old 09-03-2013, 02:03 PM
19_Skier's Avatar
Boat: 2001 19Skier
ATF, as in transmission fluid changed? (sorry, I'm not overly skilled when it comes to motors or acronyms surrounding them...) was planning on changing out with the winterization in October.
Old 09-03-2013, 02:06 PM
How long since it was last changed? Is the color still look red or is it brownish? Does it smell burned at all?
Old 09-03-2013, 02:29 PM
19_Skier's Avatar
Boat: 2001 19Skier
just past 100 hours, doesn't have standard red transmission fluid PO must have changed to engine oil. No burnt smell.
Old 09-03-2013, 02:38 PM
which transmission does your boat have?
Old 09-03-2013, 03:00 PM
19_Skier's Avatar
Boat: 2001 19Skier
You would ask me that . Since a photo is worth 1000 words, here's the best info I have at the moment.
Old 09-03-2013, 03:11 PM
Boat: 1998 Maristar 200VRS
I don't believe that there was ever a change to the fluid for the 1:1 transmissions. The optional switch to engine oil was for the V-Drives of that era. So, and I may be mistaken, I think you're supposed to have ATF in there if it's really a 1:1.
Old 09-03-2013, 03:36 PM
19_Skier's Avatar
Boat: 2001 19Skier
You know what, I just looked up the indmar manual and zoomed in on my picture. It's a ZF Hurth 450A with a 1.5:1 if that makes a difference?
Old 09-03-2013, 03:59 PM
Did you look in the manual to see what lube is recommended?
