Old 09-03-2013, 12:32 PM
Ken ruts Ken ruts is offline
Boat: 1997 prostar lt1
help
I have a 1997 pro star lt1 , the boat runs great but if I run and stop it seems to heat soak and will start but runs bad almost won't run , If after I stop running it and lift the engine box open it will run great the next time I start , that's how I ran it all weekend it seems its not overheating , any one have this kind of issue?
Old 09-03-2013, 12:40 PM
Check your t-stats, and let it idle a bit before you stop - to minimize heat soak spike... there are a bunch of threads here on this issue.
Old 09-04-2013, 10:47 AM
nrojay nrojay is offline
Boat: 1995 ProStar 190 LT1
Have you done the vent tube Mod
Old 09-04-2013, 01:02 PM
NO What is it ?
Old 09-04-2013, 06:29 PM
LT! mastercraft service bulliten MC96
Here is the attachment LT1 BULLETIN MC96-001[1].pdf
Old 09-04-2013, 08:46 PM
Thank you very much I will give it a try,Thanks again
Old 09-04-2013, 10:06 PM
Any other work done lately
Have you also checked the thermostats, there is 2, The top one is a drilled 160 degree and the middle one just above the water impellor is a 140 degree, but your symptoms sounds like the rear vent tube being clogged. This mod should work it out
