Originally Posted by Stefan
Oh well another throughly lake tested boat...
I had similar problems with a 2012 so I gained some knowledge of the boats electronics...
Suggestions for finding the reasons why the speedo doesn't work: with ignition turned off disconnect the GPS Sensor in front of the windshield (plug right underneat the hull behind the seatback), the system should then revert to PerfectPass and show that in the touchscreen, see if you speedo stays dead. Suggestion to exchange the speedo completely since it's the main and central user electronics element present in all the boats (at least in 2012 that is) dont't forget pitch and roll calibration afterwards...
The blige should have the malfunction switch inside, so a full exchange should solve it...
2012 has completely different electronics than 2013. Crappy medallion system is gone.
My 2013 X2 has not had any problems. Which system do you have (the big touch screen or the smaller screen)? I have the smaller one and it has not had any problems.
Work with your dealer. MC will make it right.
