  #31
Old 09-13-2013, 06:15 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
Sounds like a good plan. Look for loose wires, corrosion and broken wires leading to no where. I would still check your ground strap. There should be one to the block or tranny but sounds like you are beyond that now.
1996 Prostar 205 LT-1
Old 09-13-2013, 11:13 PM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
Well now I'm upset. My (mechanic) fried all my gauges today. Volt meter, oil pressure, temp, tach, and fuel gauges do not work. Not sure how he fried them but they are not working. Maybe it is coincidence. Is there anything like a master fuze or breaker for the gauges?
Old 09-13-2013, 11:46 PM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
My tach with the LCD display failed and caused all other gauges to stop working. I unplugged the tach/LCD and all other gauges started working again. After replacing with a functional tach/LCD all was good. Try unplugging the tach and see if you have the same luck.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot.
Old 09-13-2013, 11:53 PM
I will try that tomorrow. Thanks for the advice
Old 09-13-2013, 11:54 PM
Do I have to use mastercraft gauges or can I replace them with faria gauges?
