Old 09-01-2013, 11:44 PM
Squash20 Squash20 is offline
Boat: Mastercraft, PS197, 2003
Winterize procedure
Hey everyone....I know, sucks to be thinking about it, but I'm planning for the inevitable and had a few questions. I've been playing around a little and think I've got a decent process mapped out when the time comes...and just wanted to see what a few others might think. I've got a PS197. I just rigged up my homemade version of a "fake-a-lake" with an old cooler (water tank) and some fittings....keeping the cooler/tank full with a garden hose water source. It seems to work really well running the engine and sucking water from the "cooler tank" that I've created. My plan, when the time comes, will be to get water drawing through to get the engine/thermostat up to temp (engine at idle only of course). That appears to take about 5 to 10 minutes or so from the 1 trial run that ive done....carefully watching the water source to ensure that isnt starved and watching engine temp. Once at temp (around 140 degrees) I plan to shut down the engine and manually drain the engine of all raw water and then switch my cooler tank over to RV pink antifreeze (100%, not diluted). Then, re-fire the engine and draw a good 8 gallons of RV antifreeze through and shut her down. I had planned on keeping the antifreeze in the engine then (not draining) for the winter. I suppose I would just pop open the block drain plugs to make sure they show antifreeze in them as a precaution, but not draining entirely as I understand the antifreeze has rust inhibitor in it that should help protect for the winter. Does this sound like an adequate plan? I don't have any hot shower or heaters....so it is just the engine that I'm working with. The other standard maintenance will follow as well (fuel filter, engine oil/filter, all other lubrication procedures, removing water pump, etc, etc). Let me know what you all think. Thanks!
Old 09-01-2013, 11:55 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Sounds about right to me. Change the oil while the engine is still warm. The oil will flow out easier. I don't understand the removing of the water pump part, though. If you mean remove the impeller, won't all your antifreeze run out?
Old 09-02-2013, 12:05 AM
Yeah... I meant impeller...I suppose I could just leave it in and replace it in the spring. I don't think I'll lose much antifreeze if I remove it. Maybe just whatever is in the line up to and around the water pump, but everything else in the block and manifolds should be fine and should not be affected. I've removed the water pump impeller cover before just to check the impeller and replace the gasket and it didn't seem to lose much water, so I thought opening and removing it as part of the winterization process would be OK. Thanks for the feedback!
Old 09-02-2013, 12:11 AM
Jerseydave's Avatar
TT Hero
I do almost exactly what you have stated, but I change the oil and trans fluid first.
I also use -60 purple anti freeze from West Marine, only 4 gals. (8 gals. seems excessive)
Remove spark plugs and fog cylinders.
Replace impeller every 2 years in the spring.
I was njskier on here.
Old 09-02-2013, 12:25 AM
Thanks Dave. So, you don't fog through the throttle body, but rather direct into the cylinder, eh? After removing the spark plugs, do you just add the fogging solution and then replace the plugs and turn over the engine a few times (tether removed to avoid from the engine firing)? Then replace plugs in the spring and it fires right up? I was thinking about fogging the engine but wasn't sure as it seems to be about a 50/50 split between guys doing it and others not. Sounds like a good idea to me.
Old 09-02-2013, 12:18 PM
Since this is now September 2 -- winterization questions are acceptable.. I have 2 more months
Here's some procedures...
http://www.mastercraft.com/teamtalk/...39&postcount=6
TBI is a wet intake so some fogging should be done there... some ATF or Marvel (MMO) should be done...
Old 09-04-2013, 10:54 PM
johnboat johnboat is offline
Boat: MC prostar 190 1995 LT1
Good idea, what size cooler are you using? I agree on removing plugs and fogging the cylinders.
Old 09-05-2013, 09:19 PM
Hey John...I'm not exactly sure the size of the cooler (no markings on it) but if I had to guess its probably about a 60 quart (15 gallon) cooler. It works great. Fits perfectly in the boat and I literally walked into the Ace Hardware store down the road and had the fittings in my hand in about 5 minutes to convert from the cooler drain (standard garden hose diameter) to the 1 1/4" water intake hose on the boat. I think the fittings were about $7 total. Hook it up, fill the cooler and keep the hose running to keep the cooler tank full. Very easy and surprisingly not even that loud on land. And here I was thinking that I would be bothering the neighbors!!!
Old 09-06-2013, 02:03 AM
NWMike's Avatar
NWMike NWMike is offline
Boat: 1993 Mastercraft Prostar 190, 285 hp HO, 1:1
Don't forget to run the fuel stabilizer (Sta-bil) before you start the process to get it through the lines first. Carbureted engines (yours is injected) are a must as well to treat the fuel in the bowls. Treat the fuel in the tank in advance so that the treatment will distribute itself in the tank unless you can tow the boat around the block or plan on one more trip on the water.
Old 09-06-2013, 11:46 AM
bsloop bsloop is offline
Boat: 91' MC 240sc
I start running stabilizer Sept 1, fuel burn decreases and then all gas is good.
Fuel starts to age the moment it leaves the refinery. If you wait til winterization time, that fuel has had time to degrade. Many variables but most agree fuel has fallen off by a grade in 2-3 months. So the portion of fuel left in your tank from earlier fills has now degraded.
I try to change my oil end of season but don't get wrapped up that it is the last thing done before putting her to bed. Every time an engine is brought up to temp, any moisture is driven out and our boat motors get hot every time we use them, unlike grandma's engine that sludges up because she only takes 2 mile trips and never properly warms.
Fog through the intake is sufficient for most winter layups (or none at all if it is short time and kept dry). When I do fog, choking it down as the coolant is sucked in. Fogging the cylinders is good protocol for LONG periods but be prepared for fouled plugs in the spring. Personally, I would not cylinder fog unless layup was planned for a year or more.
Definitely pull plugs to drain water then antifreeze and pull plugs to check it ran completely thru system. I go ahead and drain antifreeze. The anti corrosion properties of any liquid left still protect the motor as it sits and there is no chance of a dilute antifreeze mixture freezing in extreme conditions.
