Old 08-31-2013, 08:57 PM
johny123 johny123 is offline
Boat: 2000 PS195, 350 Predator TBI
No crank, no click, battery 12.v - help plz
I'm getting no crank when I turn the key. The gauges fire up when the key is turned, it sounds like the fuel pump is making noise, but no click from the starter/solenoid and nothing but a beep when I turn the key.
I tested the battery, 12.7v, cleaned the posts (they were already clean), tested the solenoid 12.7v, and checked for error codes - I get code 12 which is "normal condition (diagnostics system is operational)" - (as an aside, *** is the point of this code?).
Here are my questions:
1)Could the battery could still be bad even though it says 12.7v?
2)Does 12.7v at the solenoid mean I can rule it out?
3)Could the ignition switch be the problem even though the key positions do respond appropriately?
Thanks for the help guys
Old 08-31-2013, 09:05 PM
I would check the ground at the engine block.
Old 08-31-2013, 09:58 PM
carracer's Avatar
carracer carracer is offline
Boat: MasterCraft 2008 X30
Hook up a charger on jump and rule in or out the battery,could be Solenoid not closing when the key switch /wire is hot. Cheap to replace I carry an extra solenoid in my tool box....
Old 08-31-2013, 10:54 PM
Mastercraftdave's Avatar
Mastercraftdave Mastercraftdave is online now
Boat: 2015 X23 SS 6.2L
Did you check the emergency kill switch lanyard?
Old 08-31-2013, 11:16 PM
madcityskier's Avatar
Lanyard should let it crank, but not fire. Correct?
Old 09-01-2013, 12:03 AM
Correct!
Old 09-01-2013, 05:38 AM
masterx10 masterx10 is offline
Boat: 2014 Mastercraft X10
Try testing the battery voltage with a multimeter when you turn the key and see if it still stays at 12.7. Not sure you have the same problem as myself but I had a newish battery that dropped a cell. When I tested the battery by itself it would read over 12 volts but when put under load the voltage would drop down below 10 volts and would not start.
Old 09-01-2013, 08:57 AM
first of all, thanks for all the quick replies!
mr mastercraft, by "check ground at engine", what does that involve doing? when i was checking voltage at the solenoid i was using the engine ground as my negative. the engine ground looked good/very clean
carracer, is there any way to test the solenoid?
i should have said, originally the battery voltage was 12.3, would drop to 12.15 when i turned the key. after putting the battery on a trickle charge for a few hours voltage was 12.7.... that being said, i just realized the date code on the battery is august 2006. does it need to be replaced even though the voltage is still high? not sure how i can test amperage/capacity?
lanyard is good. that was one of my first thoughts...we've been through that one before
what does no click at the starter suggest? could the ignition switch be suspect in these types of problems?
Old 09-01-2013, 09:27 AM
Geezer1 Geezer1 is offline
Boat: 1995 Prostar 190
Sounds like what happened with my '86. It had a broken wire coming off the ignition switch. Good luck finding the problem.
Old 09-01-2013, 10:02 AM
Bob B Bob B is offline
Boat: 197 ProStar 2002
I had a similar problem. Charge the battery. It would show charged. 12.7v but would not start boat. Took the battery to Walmart.. It had a dead cell. New battery solved my problem.
