How to use the trailer brakes while parking on driveway?
My boat driveway is a little steep. I use a concrete block to put between the trailer tires to keep it steady. I want to know if there's a way to lock and unlock the trailer brakes while parking on the boat driveway ? It would be nice to be able to use the brakes to keep it there instead of rolling back and forth.
I don't know if the trailer breaks would keep it from rolling sans tow vehicle.
Previous: 1993 Prostar 205 Red 1998 Ski Nautique, PCM GT40, 310 hp, , Acme 4 blade, Perfect Pass SG/Zbox. FAQ Be kind. Have fun. |
A slide pin on each side is an excellent idea !!!! I wonder where can I find a slide pin ?
Let me re-iterate, I've never tried this and cannot attest to it's safety or child proof characteristics.
In my vehicles, the parking break takes some pressure off the "park" gear, but I still feel it settle in. On your trailer, there's no gearing to keep it from rolling. I'd test it on a very gentle slope with several friends present holding onto your boat tightly, etc. I don't think those breaks are going to keep it from rolling if your driveway has any sort of grade to it. I could easily be wrong, but I don't trust my recently reworked brakes that much.
#7
This may sound like a strange question, but when you park the boat, is it facing uphill or down?
Most drum brakes work well in the forward direction, but poorly in reverse. That's why you can still back up with your E-Brake on. In addition, if they are electric brakes, they are weaker still, so you'll have less holding power. I also have a steep driveway, and I've parked trailers on it often. I usually block all the wheels I can, and I don't use the nose jack wheel. The other thing I've thought about doing is putting a concrete anchor in the ground, and then attaching a cable to the tongue of the trailer from that anchor... Good Luck! |
#8
I would think that relying on the trailer brakes to hold the trailer and boat on any kind of grade is a recipe for disaster. I'm sure if you did this for any length of time you would get up one morning to find your boat at the bottom of the hill. If you do this I would strongly recommend using a block in front of the wheels as a fool-proof safety brake, which is basically what you do now, so I'm not sure you would gain anything.
Just my suggestion. If I have misinterpreted your question, which is quite possible, just ignore my response. Good luck with your boat. Bruce
1990 Prostar 190, 351 Indmar SO, bought as an empty shell and rebuilt over the winter (04/05). Sold in May 2009 New boat - 1993 Prostar 205. Bought in better shape than the 190 was but still needed some work. |
Thread Tools | |
Display Modes | |
