Old 08-29-2013, 09:44 AM
eriksen4 eriksen4 is offline
Boat: 91 Maristar
Mine drove me crazy with same problem, although older 1991 Maristar. Ended up being the electronic ignition was breaking down after engine warmed up. When cooled off, boat cranked and started like a charm. Not troubleshooting your problem, just giving my experience. Good luck!!!
Old 08-29-2013, 01:20 PM
eurosysytem0's Avatar
eurosysytem0 eurosysytem0 is offline
Boat: X7 MCX350
Hi
Ive got an X7 and I am in the UK. I cannot offer you a solution (not clever enough) but I would be really appreciative if, when you solve the problem,you let us all know what fixed it.
A PM would be really helpful as I would hate to miss it on new posts. Good Luck
Old 08-29-2013, 05:11 PM
wheeler's Avatar
wheeler wheeler is offline
Boat: 2007 X2
*cough*....relay switches??? At least try them.
3 big black things close together at the back of the engine on top....
2007 X2 - Current
2004 X10 -Sold
1997 ProStar 190 - Sold
1993 ProStar 190 Star & Stripes - Sold
Old 08-29-2013, 06:02 PM
Mgboyd25's Avatar
Mgboyd25 Mgboyd25 is offline
Boat: Mastercraft, X7, 2004, Yellow
Originally Posted by MikeyOrange88 View Post
When you say "it would not completely turn over", you mean the starter is turning over very slowly, somewhat like when you have an almost dead battery? It may in fact be the starter itself. Several posts on here where that was the issue. Seems a little premature for a 2004 boat, but possible I'm sure. It would cost nothing to remove starter and have it bench checked at an auto parts store.
Mine had the slow hot start condition as well. It would just barely turn over, leaving you stranded. Next time, cold start in driveway, had no issues. Several cycles like that will drive you crazy. I replaced starter with a new Arco gear reduction type and problem solved. Starters can look fine and still be bad.
Of course, you should have already checked the cables, terminal connections, ground, etc. I'll say it before someone else does, Stop throwing parts at the problem until the problem is diagnosed, especially expensive ones like ecm's and fuel pumps.
Not sure why dealer would think the ecm is bad if it is not turning over? Maybe I'm misunderstanding the issue. Does it (crank) turning over freely, just doesn't start when hot?
I apologize it I wasn't clear enough but I think the starter is fine as it is cranking. It seems like it isn't getting enough fuel to get going fully.
2004 Yellow X7
Old 08-29-2013, 06:03 PM
Mgboyd25's Avatar
If the ECM replacement didn't cure the problem, I would hesitate to consider them AWESOME.
Did they connect it to a diagnostic computer to view the data? If not, why not? That would rule out a lot of possible causes.
Open the throttle a little and see if it starts. If it does, make sure the ECT is good.
Thanks for the input Jim, I will see what kind of data they received from the new ECM
2004 Yellow X7
Mgboyd25's Avatar
^^^^ what he said... what's the engine temp when this happens?
The engine temp is normal when this happens
2004 Yellow X7
Old 08-29-2013, 06:05 PM
Mgboyd25's Avatar
Originally Posted by wheeler View Post
Check your relay switches. They are on at the back of the motor on top. Should be 3 of them. I run into the same problem a couple of years back. In and out of the water, thought it was pump, changed that and ran for a while and bam, down again....after a thorough inspection of all wires, fuses, switches, ignition blah, blah....we found it to be one of the relay switches. Pulled it apart and there was a burned spot on one of the prongs. Move it one way, boat would fire, move it another and boat would not.
relay switches are $14. keep one handy, it has happened to other boating friends of mine, and the first thing they do is replace the pump only to still have problems later.....
give it a look.
Thanks! I will check and see if that might have been the issue. My neighbor is an electrician and he said he had a similar problem with his mustang and that was the culprit
2004 Yellow X7
Old 08-29-2013, 06:06 PM
Mgboyd25's Avatar
Wow that's interesting. How did you finally diagnose that as the problem?
2004 Yellow X7
Old 08-29-2013, 07:17 PM
Originally Posted by Double D View Post
I was also there when our fellow TT member was running the diagnostics. When they tried to start it acted as if it was starving for something and there was a lot of fuel smell in the air, so we all guessed "AIR". He then 'exercised' the AIC (I think that was what he did) and it started right up. However, after running it back to the ramp and loading it up, he shut it off and tried starting it again, with no success.
It wasn't starving for air as much as it was delivering too much fuel. During cranking, the ECM is programmed to deliver fuel based on coolant temperature, barometric pressure (sent by the MAP sensor) and throttle position. If any of these is wrong, it will cause hard starting but a closed IAC will only require opening the throttle to start the engine. If the IAC is operating and it requires opening the throttle to get it to start, it's usually the ECT and if the MAP or TPS are sending bad info, it should start but it might surge, it will run like a dog, use a lot of gas and top end will suffer.
Old 08-30-2013, 08:02 AM
wheeler's Avatar
Boat: 2007 X2
Mine just happened to be the fuel pump relay switch. drove me nuts for a year.
2007 X2 - Current
2004 X10 -Sold
