Old 08-24-2013, 11:57 AM
88inNH 88inNH is offline
Boat: 1988 ProStar 190
Drip behind Raw Water Pump
1988 Prostar 190
Ford 351
Conventional ignition / points (needs a tuneup)
Engine will occasionally "cut out" while driving (goes dead electrically as if I had turned off the key). Assumed grounding problem of some sort but figured I'd check my "marginal" battery and alternator before pulling the dash apart, etc.
Opened engine cover / hood with engine running and noticed a fine mist. Turns out water is dripping from the shaft behind the Raw Water Pump. The water drips right onto the pulley / fanbelt behind/below it and gets sprayed onto the front of the engine / alternator / fan belt, etc. Thinking back, I may have heard fan belt slipping in an engine "cut out" episode.
I likely have multiple problems going on here. But is seems like eliminating water spraying on the belt / alternator might be a good starting point.
Question #1 - Any ideas on the drip on the shaft behind the raw water pump? To be more accurate, there are slots in the casting of the raw water pump where you can see the shiney shaft spinning. The water is dripping out there (so I guess technically the leak is in the pump. It's just not up front where the impeller is. Is this a seal / gasket or failed pump? DIY?
Question #2 - What are the chances that the spray and slipping belt is causing the electrical problem?
Question #3 - If not, any hints on tracking down the electrical? My plan is to just disconnect / clean / reconnect everything I can get at (behind dash, battery, alternator, starter / solenoids). Anyone ever put together a list of what to check and what order? I've got a DVM - is it worth taking readings or just better to clean everything?
Question #4 - The boat runs ok otherwise (other than needing a tuneup). Temperature fine, etc. Voltage at battery is ~12.45, jumps to ~13.45 when running (volt gauge in dash reads about 1.5 volts lower). Is it bad to run it like this with the occasional cut out?
Thanks
Old 08-24-2013, 12:35 PM
John 3:16-18
Old 08-24-2013, 02:23 PM
@Cloaked
Thanks for the quick reply. I'll attack as two separate issues: pump and ground.
My pump says Johnson Pump F6B-9.
Agree - $185 vs $110 seems a no-brainer.
Where did you get yours (PM me if it's inappropriate to post sources).
Does pump just slide off after unbolt (3 allen bolts on pulley behind it, bracket) or is some sort of "puller" involved?
Out of curiosity: Anybody ever rebuild a F6B-9? Does it takes more than an hour or require special tools?
Just thought I'd toss that back out for comments/hints while I start cleaning connections.
Old 08-24-2013, 02:32 PM
Originally Posted by 88inNH View Post
@Cloaked
Bunch of people have rebuilt their pumps... check this thread - post #2 has direkshuns...
http://www.mastercraft.com/teamtalk/...509#post168509
Old 08-24-2013, 02:34 PM
John 3:16-18
Old 08-24-2013, 06:22 PM
BG1772's Avatar
BG1772 BG1772 is offline
Boat: X-Star, 2001 5.7L LTR
If you have a bench vise and a deep well socket of the same size as the bearing, it is pretty easy to rebuild.
2001 X-Star 5.7l LTR
Old 08-24-2013, 06:24 PM
I had similar problem when my water pump failed. Engine was running extremely poor (never having done that prior), raised the engine cover and saw water spraying everywhere from broken pump (rear of unit). Purchased and installed new water pump and no further issues with the engine missing.
Definitely treat water pump replacement as step one. Changing water pump is straight bolts off, bolts on replacement. Good Luck
Old 08-24-2013, 06:27 PM
John 3:16-18
Old 08-24-2013, 06:28 PM
i am in the replace it all camp too... especially this part...
Old 08-24-2013, 07:32 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
My Johnson pump was leaking at the aft end.
Pulled pump, new $25 seal and reassembled.
Easy job, maybe 30m work. I wrote it up with pics and so on a few months ago. Maybe search for it...
My local (expensive) boat shop wanted to replace pump too when I got seal from them. I am sure that would have been a $500 job for my 30m worth of work and a seal.
YMMV of course.
