Old 09-09-2013, 11:06 AM
MI_Corey's Avatar
MI_Corey MI_Corey is offline
Boat: 2008 X1
Rub rail peeling away, what to do?
Well, I finally figured out where I'm taking on water yesterday. I was always confused because I only took on water while wakesurfing. I realized yesterday when it started coming in the side pocket that the rub rail is separating from the boat on the back where it dips down. I would take a picture but there's really not much to see. Just a gap between the rail and the fiberglass. What do I need to do to fix this? Is it a major issue or can I just drill the rivets out and use larger ones? I thought I had ran across a thread on here before of another Maristar or Tristar that had the same issue but I couldn't find it. Any helpful advice is appreciated.
Old 09-09-2013, 11:27 AM
I have had to replace a couple rivets on mine and I simply drilled the rivet out with as small a drill as possible and replaced with the same size rivet.
Old 09-09-2013, 11:44 AM
MI_Corey's Avatar
Boat: 2008 X1
Hopefully that's all it will take.
Old 09-09-2013, 11:50 AM
You should send a message to a Moderator (Sodar) to get you off the guest status.
Old 09-09-2013, 12:03 PM
tph's Avatar
tph tph is offline
That gap is filled with silicone sealant on my boat.
Old 09-09-2013, 12:18 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
I think you will more than likely have to remove the rivets as MrMasterCraft said, then apply silicone and new rivets. If you put silicone in there without removing the rivets, it may not fill the holes where the water is coming in. I had this issue on a couple of boats in the past and tried just silicone, but it didn't help. I sold the boats before I got around to fixing, just bc it really wasn't enough water to be concerned with for me.
Old 09-09-2013, 12:20 PM
Yup, don't forget some silicone.
Old 09-09-2013, 12:23 PM
MI_Corey's Avatar
Boat: 2008 X1
ok thanks! ... and I did send a pm to a moderator at some point but I don't remember who. I will look up sodar
Old 09-09-2013, 12:38 PM
Traxx822's Avatar
Traxx822 Traxx822 is offline
What kind of MC do you have MI Corey?
1 Corinthians Chapter 13 - 11
Old 09-09-2013, 12:59 PM
MI_Corey's Avatar
Boat: 2008 X1
93 Maristar DD. It's the one where the rub rail dips down at the back of the boat because the swim platform is all one piece.
