Old 08-17-2013, 01:36 PM
clrussell's Avatar
Need some help from the camper guys
Recently got a camper, older but in great shape. Had to pull it to dads shop with his flat bed truck because of the hitch height and today I finally hooked it to my truck for the first time after adjusting the hitch. But as you can tell from the picture the camper does not sit level at all. I had it in my mind to put the springs on top of the axle and pull it that way. I know this is possible but I'm just looking for input from others who have been here before. Should I pull it how it is? Should I put the springs on top of the axle? If I do the spring over will it feel more top heavy? Or just drop the neck about an inch and pull it? Any input?? Thanks guys
Name:  ImageUploadedByTapatalk 21376760960.185096.jpg
Old 08-17-2013, 02:17 PM
heath124 heath124 is offline
Boat: 1990 prostar 190
How much space do you have between the top of your truck bed and your camper. It looks like in the picture there is a lot. It should be between 8-10". I have had to flip the axles on a couple mine. It looks like you could adjust your hitch in the truck or your kingpin on the trailer.
Old 08-17-2013, 02:47 PM
clrussell's Avatar
I probably have 10" right now, forgot to add that the trailer has been converted to gooseneck ball and doesn't use the 5th wheel plate. When you flipped the axles on top did It make it pull any different?
Old 08-17-2013, 03:19 PM
dog paw's Avatar
dog paw dog paw is offline
Boat: 1984 19 skier Powerslot
I have put block kits in a couple of gooseneck horse trailers to level them up,but they had torsion axles. All seem to have been on late model trucks. dexter has over under kits available. http://l.b5z.net/i/u/6149609/f/Trail...Adjustment.pdf. That might help some I'm sure there are other kits out there also.
A running apology for misspells and general butchering of the Kings English
Old 08-17-2013, 04:58 PM
clrussell's Avatar
I've got all the pieces to swap it to spring over, I just wanted to talk to a couple people who had before I did it. My dad sells trailers and equip so parts were easy
Old 08-17-2013, 05:22 PM
None of mine pulled any different and my dad also did one of his campers and they all pulled fine.
Old 08-17-2013, 08:17 PM
clrussell's Avatar
Cool, that's what I needed to hear. I guess when it comes a rainy day I'll get it lifted!
Old 08-17-2013, 11:30 PM
Jerseydave's Avatar
TT Hero
Hard to tell, but the gooseneck looks pretty long where it connects to the truck.
If you have enough clearance above the bed sides, maybe you can shorten the gooseneck 3-4 inches.
Even if you add 4" to the axle spacing it's still not going to be level. Because your truck is lifted, I think you need to lower the nose of that trailer somehow. Can your truck be lowered back down to stock height?
I was njskier on here.
Old 08-18-2013, 12:49 AM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
is your truck lifted? very clean by the way!
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 08-18-2013, 07:01 AM
clrussell's Avatar
Truck isn't lifted, just leveled with 33" tires. I can shorten the neck a little but I'm afraid if I go much I won't have any bedsides left
