Old 09-10-2013, 07:23 AM
michael79 michael79 is offline
Boat: 2005 205 Prostar V
I did find an inline fuse for the MMDC. I think it was a 3amp. I also, found one for the paddle wheel and one for the perfect pass (which my boat does not have). I never found a second fuse for the MMDC. Do you know where yours was located? I am pretty sure as much as my dash was torn apart it is not under/behind kick panel or under dash cluster.
Old 09-10-2013, 04:37 PM
f16driver's Avatar
f16driver f16driver is offline
Boat: prostar, 197, 2003, northstar LQ9
check out this link: http://www.mastercraft.com/teamtalk/...ad.php?t=31131
I pulled the black wire casing in from behind the kick panel and found 2 fuses. IIRC one was a 3 amp and the other a 10 amp or volt? But these fuses caused my guage problems. Visually the fuses looked fine but as soon as I replaced them my gauges started working properly.
Good Luck
Old 09-19-2013, 09:33 PM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
F16driver- you have any pictures of the fuses locations? I am having same issues and can't find any fuses. Thanks in advance.
Old 09-30-2013, 10:28 AM
F16 I have not had chance to replace fuses but will try tomorrow just to make sure that is not the problem. I have checked them with my multi meter and they did have continuity. I even pulled them out and the noticed that the gauges did not do anything (the LCD display did not work, and I think the gauges did not attempt to wind up). I don’t remember a 10amp fuse but will look again.
Topp dawg, the fuses in my boat are in two locations. All the instrument (gauge fuses) are under the dash behind the kick panel. I have found the best way to access them is by removing the subwoofer and fishing them out. On my boat there if memory serves me correctly I have the following:
3 amp MMDC fuse, not 100% sure on size
5 amp perfect pass fuse -- even though I don’t have perfect pass, not 100% sure on size
2 amd fuse for paddle wheel, not 100% sure on size but I do recall this was the smallest fuse.
And there is a relay for buzzer.
all the above is under the dash, and in engine bay area this a strip next to test port with 3 10 amp fuses, but I think these are for the fuel injection and ECU.
Old 10-02-2013, 09:38 AM
jardmurf17 jardmurf17 is offline
Boat: Mastercraft Prostar 190. 2002. 5.7 Indmar
Did you find a solution to your gauge problem? It sounds so similar to a problem I'm having now with my 02 190.
Old 01-14-2014, 02:58 PM
I finely got my gauges working. My ECU was bad.
