Old 08-21-2013, 01:27 PM
Flatwaterfooter Flatwaterfooter is offline
Boat: 2006 PS 197
Boat wgt. vs Lift
Have an opportunity for a 3,600 lb lift. am I cutting it to close for my 06 197. Dry boat weight is 2620 lbs gas figure another 200 has mini tower not sure of the weight plus gear and passengers. What are your thoughts
Old 08-21-2013, 01:33 PM
Rockman's Avatar
Rockman Rockman is offline
Me personally would not go less than a 4,000 lb lift for your boat.
What condition is the lift in? How are the cables?
Old 08-21-2013, 01:40 PM
Boat: 2006 PS 197
Good condition new cables and hardware
Old 08-21-2013, 01:50 PM
Rockman's Avatar
IMO, I would go to a bigger lift but some people on here may disagree. I think the lift we have for our BF200 is rated for 4,600 lbs which covers the weight of the boat, all our gear and full tank of gas.
I believe the steel of the lifts for 3,600 and say 4,000 lbs are the same but the cables and winch may be different.
Someone will chime in here soon...
What brand lift is it?
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
The brand of lift also makes a difference. In most cases the difference between a 3k -and 4 k lift are the size of the cables. An easy upgrade on most . Again tho depends on brand
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 08-21-2013, 01:54 PM
h2oski89 h2oski89 is offline
Boat: Mastercraft, X9, 2006, 350 MCX
I have a 2006 X9, dry weight is 2850. I put it on my 3600 lbs Hewitt Cantilever Lift and it is rock solid, brand new cables and pulleys. I replace the cable if it starts to look frayed! If you have the option to go with a bigger lift I would do it but the 3600 lbs should hold your 197! I don't lift the boat with passengers, just gas and gear!
Old 08-21-2013, 02:18 PM
jkski jkski is offline
I had a Hewitt Cantliever lift rated for 3000lbs that I set my 197 with full tower on for many years without issue. As mentioned by others, just inspect the cable and make sure the pulleys are in good shape and you won't have any problem.
Old 08-21-2013, 02:57 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
3k lbs would be pushing it, but the 3600-4000 lb lifts Ive seen are in a different category. Gear reduction, etc. I'd say thats about the least I'd consider for that sized boat, but it'll get the job done.
Old 08-21-2013, 03:08 PM
blakehardesty's Avatar
blakehardesty blakehardesty is offline
Boat: MasterCraft Skier
If it is a Shore Station brand you will be fine. My friend has a Supra something or another wakeboat on a 3,600 Shore Station and it has been on there for 5 years with no problems. I know the supra is bigger than you 197
1984 Mastercraft Skier 1:1
Old 08-21-2013, 03:23 PM
Boat: 2006 PS 197
Yes it is a shore station
