Old 08-20-2013, 03:50 PM
stuartmcnair's Avatar
stuartmcnair stuartmcnair is offline
Boat: 1989 Prostar 190 351 Indmar
Send a message via MSN to stuartmcnair
Blue Smoke on Start
OK, I recently had to put a new carb on my boat and ever since I did that the boat will smoke after I start it. This only happens after it has been sitting a while. Once we start going or on restarts throughout the day it does not smoke.
I know the new carb should have nothing to do with that but that is when it started happening.
Very frustrating.
Any ideas from the engine gurus?
Old 08-20-2013, 05:10 PM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star
I'm no engine guru, but I believe blue usually means oil.
And from what I've been told, blue on startup tends to be worn valve guides.
2002 X Star
Sold - 76 S&S
Old 08-20-2013, 05:57 PM
cruiser cruiser is offline
the longer the engine sits, the more oil can drip into the cylinders. Blue smoke is oil.
Old 08-20-2013, 06:48 PM
Valve seals aren't a terribly difficult job, but re-installing the rocker arms does require doing it correctly.
Most valve spring compressor tools suck and compress only one at a time. If you can find one that compresses both, use that. Get a manual so you have the instructions WRT how to tighten the nuts that hold the rocker arms. You'll need a compressor and an air hose that threads into a spark plug hole, to keep the valves from dropping into the cylinders.
Old 08-21-2013, 10:57 AM
OK, so I understand that blue smoke is oil. Jim was nice enough to tell me how to handle it but now I need to know the answer to the real question. How much is this going to cost to fix with someone else doing it? I do not do engines...
Old 08-21-2013, 08:24 PM
I would call around- this can be done by anyone who services engines in cars, trucks, boats, etc. If you have a trusted mechanic for your cars, ask them. IIRC, it took a couple of hours for us to do the valve seals on my pickup and that had more accessories to remove for access. On a boat, if the valve covers come off without removing the exhaust manifolds, it would be a lot faster- removing the manifolds would speed it up considerably since removing the spark plugs can be a PITA and they may need to come off to allow removing the valve covers, anyway.
Old 08-22-2013, 10:52 AM
Thank you sir!
