  #31
Old 08-30-2013, 07:35 PM
Greenwood87 Greenwood87 is offline
Boat: 1989 Mastercraft Tri Star 190
Ok, so I got a chance today and tried to start it up (I also replaced the filter in the fuel water separator). So I turned it over with the ignition disconnected and primed the fuel system. Hooked the boat up to water (using the bucket). After a few turns HYDROLOCKED!!!!! I pulled all the plugs, water is only in the right side of the engine in every cylinder this time. I went ahead and pulled the right manifold off. I took a hose and plumbed it into the manifold, turned the hose on full, no water is seen coming from the exhaust ports on the manifold. I then connected the hose to thermostat housing, water flowed through the engine and out the left manifold. I left it there for a minute no water flowed any of the cylinders on either bank. Any thoughts where I should go now.
On a second note I'm testing the boat on a slight incline (2-3% grade), with the bow on pointing to the bottom of the slope. Could this cause water to build up in the exhaust and flood the cylinders???? My exhaust is not clogged, ran some water through and it flowed out but some water did say at the bottom the exhaust.
Old 08-30-2013, 07:45 PM
Strange...... that's not good news... I wonder if one of your exhaust hoses is paritailly blocked possibly...can happen and look normal from outside...
Old 08-30-2013, 07:47 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
Are the exhaust hoses hard or soft?
Old 08-30-2013, 08:59 PM
Hoses ate rigid but they are not bridle.
Old 08-30-2013, 09:02 PM
cbryan70's Avatar
Can you squeeze them? If they compress easily they may be shot.
Old 08-30-2013, 09:08 PM
Table Rocker's Avatar
I would pull both exhaust manifolds, stick the hose in the bucket and crank it. That way you can rule out the exhaust system.
'96 ProStar 205 SD LT-1
Old 08-31-2013, 07:17 AM
johnnye23's Avatar
johnnye23 johnnye23 is offline
Boat: 1979 Stars n Stripes
If it were me troubleshooting I would remove suspect manifold , I would remove the riser and make a metal plate and install in place of the riser using one of the riser gaskets . Then use a hose and pressurize the manifold if no water flows from the exhaust ports the manifold would not be the problem.
If the manifold checks good I would reinstall the riser ( with known good gasket,remember aft port will be blocked ) . I would cap off the exhaust end with a plastic coke bottle or something of the same diameter using one of the large exhaust clamps. Then again pressurize the manifold same as before and look for leaks.
For a down and dirty you can stick the hose end inside of the manifold inlet hose and clamp for testing . I still feel you will find a riser/gasket problem .
Old 09-01-2013, 02:57 PM
Ok I think I'm on the right path. Put everything back together The exhaust hoses are collapsing when starting. And the exhaust flaps are shutting closed. This can mean I have stuck valve or bent rod, however I would not have compression if this would happen. Would exhaust back pressure be enough to pull the flaps closed? Looks like I'm at least on the right track now. Any comments? and thanks for all the help guys.
Old 09-01-2013, 03:24 PM
John 3:16-18
Old 09-01-2013, 04:33 PM
You replaced the starter and it sounds to me like your starter is turning the engine the wrong direction. I would verify the engine rotation.
engine, head gasket, windsor
