1989 - might be time for a new set... I inspect my 1995 risers and and manifolds every season.
8 bucks for gaskets... cheap... and a reason to go do something on boat.
Just placed an order at skidim.com for two riser gaskets (I live in SC so 1 day shipping!!!). Also just spoke with a marine mechanic who works on my buddies Nautique. He pretty much confirmed its the manifolds or the riser gaskets. He stated that there is no way that amount of water could enter the cylinders from the heads after a few rotations to lock the engine. Ill take pictures and post.
#23
If you had water in every single cylinder (and a lot of it) then my bet would be exhaust manifolds as well. If you had noticed water dripping out of the ports when you removed them to pull the heads, that would have been a big clue. Failed riser gaskets can do the same thing, but usually wont allow gross amounts of water in very quickly (thus hydrolocking the motor).
I would pull the exhaust manifolds and pressure test them. Both would have to be junk for you to get water in both banks- but Ive seen it happen due to an overheat. I have seen intake manifolds crack from the same overheat, and that will exacerbate the water in the oil symptom. It sounds like the boat sustained some damage prior to you getting it... I'd consider pulling the intake and looking for evidence of water intrusion in the valley while you have it apart. How long has it been since the water showed up? If its been more than a few days, theres a chance your fresh heads may be all rusted up in the area of the exhaust valve seats. Dry it out ASAP and compression test. |
#24
I think I will pull the risers tonight get the manifolds pressure tested, and check the torque of all the heads and intake. When I had the intake off last it was in great condition, but of course I didn't have it test or anything. Has anyone purchased the 159.00 manifolds on ebay? They say they are made in the good old US of A. I wonder if they are any good. |
#25
Ok here is the sad condition of the riser gaskets. I can see no visible cracks in the manifold. I'm really think this is my problem. Both sides are in this condition.
#26
Ok got new riser gaskets in, changed the oil, so I will be testing the engin today. I replace the bolts on the risers with grade 8 bolts, I know these are not stainless will they rust?
#27
Wrong head gaskets? Wrong torque? Wrong sequence?
Tim "Heavy" beer is for wine drinkers that are too embarrassed to drink wine in front of their buddies. "Light" beer is a drinkin' man's beer! |
#28
John 3:16-18
#29
Well one of the gaskets was missing a complete piece between the water jacket and exhaust side of the manifold. So there was a direct path for water to flow into the exhaust side of the manifolds. I did a compression test on all cylinders between 120 and 135 on all cylinders. I haven't had the chance to test after I assembled the riser gaskets (I was completely tired of the dang thing and went out on by buddies sail boat). I'm going to test this Friday.
#30
Sail boat? How do you ski with a sailboat, let alone sit in the garage with a beer busting your knuckles and cursing? We don't need no stinking sail boat.
Kidding, sailing's great when it's to windy to find good water. Hobie 16's rule!
I spent most of my money on booze, broads and boats. The rest I wasted. - Elmore Leonard I had always thought that there was nothing quite so sad as an abandoned boat.-Terry Hayes |
Tags |
engine, head gasket, windsor |
Thread Tools | |
Display Modes | |
