Old 08-22-2013, 02:53 PM
LKGman LKGman is offline
Boat: 2002 X-9
Anyone Who Has Replaced the Bunks on a Prostar Trailer....
Did you have the 2x4's planed down so that they were thinner on the inside side of the bunk? Or did you just round the corners off and leave them the same thickness all the way across? If you planed them down, how or who did you get to do it? Thanks guys!
Old 08-22-2013, 03:09 PM
d2jp's Avatar
d2jp d2jp is online now
Boat: 1992 PS 205-351w,285HO
I'm doing mine soon. Was planning on ripping them with a table saw to keep the correct contour and routing or sanding the edge.
Are you on Lake Gaston?
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 08-22-2013, 03:10 PM
helton333's Avatar
helton333 helton333 is offline
left them alone - the carpet will smooth out the corners. Factory are square. I went back with 2x6 because the 2x4 had some flex in them that worried me a bit
Old 08-22-2013, 03:35 PM
occva occva is offline
Boat: 1986 Mastercraft Slot
I tapered mine and eased the edges. The hull sits flat on the 2x4's.
Old 08-22-2013, 03:53 PM
19_Skier's Avatar
19_Skier 19_Skier is offline
Boat: 2001 19Skier
I have 2x6's on mine as well, didn't realize they came with just 2x4. Just put new carpet on them, didn't plane them or touch the corners, the carpet covers everything and I float my boat on the trailer so not worried about wearing out the edges.
Old 08-22-2013, 04:05 PM
Boat: 2002 X-9
Thumbs up
Yep, we're on Gaston! A good friend of mine who does a ton of wood work said his table saw wasn't high enough once he adjusted the angle the same as the original bunk boards.
