Old 08-17-2013, 10:31 PM
nrojay nrojay is offline
Boat: 1995 ProStar 190 LT1
go to Rock Auto use this code if it works, I ordered mine from them and then I got an email for a discount code #1665232913872538
Item #P60987 (P60987:P) $84.79 plus shipping
http://www.rockauto.com/catalog/rafr...6-P60987-88113
www.rockauto.com
Old 08-19-2013, 01:22 AM
Zad Zad is offline
Boat: 2002 xstar
Question?
Are there two fuel pumps on these boats (mine is 94 prostar 205 with 350 Chev)...one on port stern side of engine by fuel filter and one in fuel tank?
Old 08-19-2013, 05:08 AM
Originally Posted by skiknox View Post
Should have mentioned this in org post. This spring I was having problems getting full rpms out at wot. I checked pump screen, psi at idle and wot, out new plugs wires cleaned coil ends where plugs connect. All checked out fine. Maybe it's time to just put a new pump in it?
You checked the pressure- did you purge the air from the gauge? Your pressure s higher than it should be on a '95- normally, it's 30 pounds. Don't replace the pump if it's not warranted.
How old are the plugs? Old gas? Have you ever looked at the fuel pickup tube that's in the tank? After 18 years, it's time to do that. Also, look for a fuel shutoff valve connected at the outlet of the tank- if the lever isn't in-line with the fuel line, it needs to be. Does the exhaust smell like gas?
Old 08-19-2013, 05:12 AM
I knows it's been discused before and I've done some searching on the cheapest place to buy the carter fuel pump but seems like they have gone back up in price anyone know a good place to purchase skidim seems high like 350.
Your pump shouldn't be that much. The boat shown with your name is a '95- that's correct, right? If so get the part number from the existing pump and google that, not the Carter in-tank pump, which you DON'T have.
Old 08-19-2013, 05:13 AM
Originally Posted by Zad View Post
Question?
Only one pump, on the engine.
Old 08-19-2013, 03:23 PM
Zad Zad is offline
Boat: 2002 xstar
Thanks JimN, and the filter that is often discussed that needs cleaning, is that in the pump or in the fuel tank?
Old 08-19-2013, 04:25 PM
They started using the in-tank pump/filter in 2000, IIRC. You may have two filters but they can't be cleaned. If you have one at the tank, make sure to change that one first- it catches the large particles.
