Old 08-13-2013, 05:44 PM
cruiser cruiser is offline
Unhappy
cant get pics to post. If the electric choke does not work, would that keep the linkage from opening the choke plate? Even if i try to open the choke plate it hits a post that sticks out from behind the electric choke. Im not sure if the linkage is set up correctly. I will continue to try to upload pics.
Old 08-13-2013, 05:54 PM
couple of pics, sorry for the poor quality. first pic the post that the plastic cam is hitting, (hard stop.)Name:  100_0793.jpg
second pic bottom of linkage from the choke plate. hitting the plastic, cant go down any further.??
Old 08-13-2013, 06:14 PM
Hard to tell from those pics, but if working properly, you can always manually open the choke. I will be able to take a better look shortly.
Old 08-13-2013, 06:34 PM
thats my problem. no matter what i do i cant open the choke plate. I hit a hard stop. That is what makes me believe the electric choke or linkage is incorrect.
Old 08-13-2013, 10:28 PM
I would take the choke cap off and see if that is the problem. There is a coil spring under very little pressure inside and there is a notch in the choke housing connected to the linkage that accepts the end of the coil spring.
Old 08-14-2013, 08:50 AM
Will look at that choke spring this morning. has to be something wrong to stop the choke plate so hard.
Old 08-14-2013, 11:10 AM
turned on the ignition, 12 volts to the choke housing. Choke plate did not open. removed the choke housing and the bi-metal spring was warm to the touch. Gave full throttle and the choke plate did not open. Something is not right with the setup. Will go down and try to take better pics the linkage setup.
Old 08-14-2013, 11:15 AM
Did you turn the choke cap to try to open the choke?
Spring should be warm as the 12 volts warms the bi-metalic spring which causes expansion at different rates.
Old 08-14-2013, 11:56 AM
Size:  45.6 KBcouple more pics. Yes i turned the choke cap and still hit a dead stop. With the choke assy. off i get a lot more travel in the assy. When i hook it all up it will not work correctly.
Old 08-14-2013, 12:26 PM
Thumbs up
Just figured it out. I noticed a small cotter pin hole at the bottom of the choke linkage. it is missing. the L at the bottom had jumped from under the counterweight to the top of the plastic. moved it below and everything works as it should. Will make a temporary until i can get the proper cotter pin. Thanks for all your help. It goes to show ya. stick with it, everything is fixable.
