Old 08-12-2013, 11:52 AM
Boostd_GSXR Boostd_GSXR is offline
Boat: 2006 X-30
Where do you leak?
It seems like I'm taking on water this year. I'm running the billage more often than normal. In the past years I would run the billage at the end of the day to get out the water that the skiers drug in, this year I am needing to run it about three times through out the day. Are there common areas for Mastercrafts to develop small leaks? Obviously I went through and checked the drain plugs already. Outside of that I haven't looked to deep yet. I plan on getting into it and starting to try and trace out leaks this week or next week. This is on my 06 X-30
Old 08-12-2013, 11:57 AM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
Id check all Bilge lines for leaks and fat sacks for pin holes
Old 08-12-2013, 11:59 AM
92 190 PS's Avatar
92 190 PS 92 190 PS is offline
Boat: 2008 197
Most likely coming from the shaft packing if you've checked all of the other common areas. You can tighten slightly if you have never done so, but be sure there is still some dripping (once every 10 seconds or so). Replacing the packing is very simple and if you have not done so in the past it may be time. Good news is if this is your issue, it is a simple inexpensive fix. Good luck.
http://www.skidim.com/prodinfo.asp?number=GFO3/16X24
Ha..I take back how simple it is, I've always had direct drives. Looks like v-drives are a bit more fun.
http://www.mastercraft.com/teamtalk/...+shaft+packing
2008 Prostar 197
Old 08-12-2013, 12:01 PM
bjames's Avatar
bjames bjames is offline
Boat: 2009 X-Star LY6
I assume the water is not from taking water over the bow or transom. Also check all your water cooling hoses. Make sure the clamps are nice and tight.
Current: 2009 X-Star, Indmar 6L, 400hp, ZFT3 tower. c/w 1/9 scale R/C PWT X-Star
Owned:
2012 X25
2011 X25
2009 Moomba LSV
2009 Moomba Outback V
2008 Monterey FS180
Pelican 4 set paddle boat
plastic tug boat when I was 4
Old 08-12-2013, 12:18 PM
craig3972's Avatar
Boat: 2006 mastercraft x-star
mine is leaking from the rudder port quite badly
Old 08-12-2013, 12:27 PM
I usually leak while I am waiting for my driver to pull me up, or i find a nice tree
Old 08-12-2013, 12:41 PM
sp00ky's Avatar
sp00ky sp00ky is offline
Boat: 1994 prostar 205
I had to change the raw water pump seal this year which was leaking more than I realized. Since then my bilge has been quite dry. unless I get rained on which has been WAY TOO
often this year bilge pump rarely runs.
This forum is amazing with quality people.: I did not think i'd ever own an Inboard. Now I finally have a gorgeous 94 205 I am glad I have ya'll backing me up.
Old 08-12-2013, 12:46 PM
dsword dsword is offline
Rudder port is the place I have seen water come in in the newer(2005 and up) boats.
David Sword
Old 08-12-2013, 02:01 PM
Boat: 2006 X-30
The motor and hoses seem to be dry, I will check closer to be sure. I have not checked the rudder or shaft seals yet. Is there a good way to check those or just put the boat in the water then sit and watch the seals. Only have the three factory installed hard tanks in the boat. Hope one of those didn't crack or spring a leak. I'm guessing they are not fun to remove or replace.
Old 08-12-2013, 03:01 PM
Greenster Greenster is offline
Boat: Mastercraft Maristar 1998 LT1
Two places that mine has developed leaks is the rub rail. We have started surfing more and due to this I have noticed more water in the boat. The other place is my fault letting off of the throttle a bit too fast and allowing the wave to rush over the back a bit. Not much but it does add up.
