Old 08-09-2013, 06:20 PM
JayBrown JayBrown is offline
Boat: 1976 master craft stars and stripes
Tranny leak
I just got in from a beautiful ride when the tranny started to slip and when I parked it and lifted the dog house there was tranny fluid everywhere!! Where would there be a seal that might be leaking? And what fluid is used for the velvet tranny? 1976 s&s
Old 08-09-2013, 06:28 PM
cruiser cruiser is offline
there should be a seal between the trans and the motor and the trans and the coupling. I dont have a manual, just makes sense. Dextron is what im using in my power slot.
Old 08-09-2013, 08:09 PM
93Prostar190's Avatar
Dexron III atf or equivalent .. Check seals, and tranny cooler hoses
2008 Prostar 214 MCX
Old 08-12-2013, 09:52 AM
Do I have to pop the tranny to check the seals? The fluid that came out wasnt red?
Old 08-12-2013, 10:51 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
your transmission fluid is red.
Check your engine oil, check your transmission fluid level.
'04 MariStar 230VRS/MCX
Old 08-12-2013, 10:57 AM
Transmission fluid will turn brownish. If yours is brownish, it is definitely time to change it once you find the leak. In fact, I would fill, drain, run once, then drain and fill again.
Your leak is either motor oil or trans fluid. You should be able to tell by the smell which it is. Wipe some up with a clean white paper towel and give it the sniff test.
Old 08-12-2013, 02:37 PM
It was definitenly the trany fluid as it is emprty. It was a brownish color so I will try some fresh fluid and see if I can find the leak but I think the tranny has to come out? Not sure where the seals are?
Old 08-12-2013, 03:00 PM
If the trans was empty I would suspect a hose. An input or output shaft seal would be a slow leak.
Old 08-12-2013, 03:23 PM
etduc's Avatar
etduc etduc is offline
Boat: Something else, DD 2004 red/white/black
Most likely a hose. A common place for a hose leak is, the bass fitting that is crimped to the hose itself.(This would be a slow leak.) Or as simple at loose fitting, or blown hose.
Rear seal (on gearbox) is easy to find. Out put shaft of gear box. Front seal sometimes, you can pull your starter, and look for oil or fluid on your flywheel. Or you have to pull the gearbox. If you ran out of fluid, you probably ruined you steel and friction plates.
If you pull the gearbox, you might as well, rebuild it and replace the hoses.
Ayyyy!
2004 Red/White/Black something or other.
Formally, 1994 RED Mastercraft 205, Chevy 5.7 TBI.
Old 08-12-2013, 10:49 PM
Don't forget the o rings where the shift linkage connects to the tranny, they can leak there as well.
