Old 07-20-2013, 08:45 PM
Boat: Past: 1986 MC 19 Skier; Nautique, 230, 2009, PCM 343; 2012 X-45 ZFT4, ILMOR 6.0L. CURRENT 2010 X14V, ZFT3, RTP-1
2010 Vdig / fuel gauge issue
My fuel gauge nearly never works, it's always at empty and I have a low fuel warning all day. I know I have fuel..... I fill it after each use. Is there a master reset sequence. I've tried the battery switch thing and even the main breaker. Also my Vdig does not have the MasterCraft logo in the graphics center just a set of numbers and letters I assume a software version?
Old 07-22-2013, 02:44 PM
XStar08's Avatar
XStar08 XStar08 is offline
I would try to recalibrate the fuel sensor (if that is possible at all). I don't think it has something to do with VDIG or software.
Try to check near the fuel tank and locate a screw where you can calibrate the sensor...
Old 07-24-2013, 11:43 AM
Red 08 Xstar Red 08 Xstar is offline
Boat: Mastercraft Xstar 08 MCX
Mine does the same thing. I took the sending unit out of the gas tank and found that the float doen't float. It sinks to the bottom.
Old 07-13-2015, 01:49 PM
sjbrothers's Avatar
sjbrothers sjbrothers is offline
Boat: MasterCraft Tristar 1985, MasterCraft 1990 Power Slot,MasterCraft 1995 190,MasterCraft X14
I fixed mine with a champagne cork. See a post I did
