Old 08-03-2013, 11:59 PM
packman312 packman312 is offline
Boat: 2011 X-25
Oil Change question
Do you guys change oil at the end of season? I am 10 hours shy of change and wondering if I change early, do I also need to change it in mid Sept for end of season winterization? Thanks in advance!
Packman
Old 08-04-2013, 12:01 AM
It depends upon how many hours you put on it after the oil change. If it's just a handful, then no big deal. If you use your boat a lot, then you probably ought to change it again before winterization.
Old 08-04-2013, 12:06 AM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
oil and filter is cheap. and engine is not.....change it.
Old 08-04-2013, 12:21 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
The end of the season change is to remove the acids that build up in the oil during operation. If you only want to change the oil once, I think you would be better off running the oil you have in there an extra 10-20 hours than you would leaving used oil in there all winter.
Old 08-04-2013, 01:05 AM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
Packman
To me it is a better plan to change the oil a little earlier in the season and once again at the end of the season. I've already did my first oil change for the season as I was getting near the end of the interval and we were taking the boat on vacation. I did not want to change the oil mid vacation nor did I want to run over the interval. Now I'm 20 some hours into the current oil. Since we typically run through October and sometimes into November there is a chance I will be changing the oil three times this year. As already mentioned, oil and filter are not expensive if doing your own oil changes.
Old 08-04-2013, 01:13 AM
Very good point. Cheap way to make the engine last.
Old 08-04-2013, 01:16 AM
Boat: 1998 Maristar 200VRS
I like having clean oil in my engine over winter. I change it before the last trip of the season ( or change it and run the engine up to temp) to fully circulate the clean oil, then I feel better all winter long.
I suppose that, technically, the best approach would be to change the oil, then crank the engine with the plugs pulled for 30 seconds or so to get clean oil to all the bearing without any combustion by-products, then put new plugs in and call it done, but that's far too MCOCD for me.
/frank
Old 08-04-2013, 01:22 AM
/frank
You may be on to something, as long as the fuel is shut down. Do-able on an injected boat......not so simple on a boat with a carb.
Old 08-04-2013, 01:37 AM
Actually, it's probably easier on a carb boat. With the plugs pulled, almost all the intake air will come through the plug hole, meaning air with no gas in it. With no air flowing through the carb, no gas will get into the manifolrd. With an injected boat, you should probably pull the lanyard to disable the injectors; otherwise gas will get injected into the manifold (for TBI) regardless of the air flow.
/frank
Old 08-04-2013, 01:43 AM
/frank
Not sure if I agree on most of the intake air coming through the plug hole on a carb boat. With the small proportionate size of the plug hole compared to the intake valve, probably only 1/3 of the intake air would come through the plug hole. Now if you held a towel over the throat of the carb, that should make virtually all of the air come through the plug hole.
