Old 09-07-2004, 10:18 AM
PeteS's Avatar
PeteS PeteS is offline
Boat: 1988 Prostar 190 - 351 Indmar (1:1) / 365 Hours
Temp Gauge
Temp gauge is not working. It actually jumps up to around 130 when I fire the boat up, and then drops to 100 when it's operating. Seems odd. I've heard the operating temp should be 150 or so, so I'm assuming this 100 reading is false.
Anything jump out at anyone is quick fixes? Pulled the dash, and the wiring seems to be in tact all the way back to the thermostat. What next?
Thanks,
Pete
1988 Prostar 190 - 351 Indmar (1:1) / PerfectPass Digital Pro 6.5n, 13 x 12 Acme 3-Blade
Old 09-07-2004, 10:45 AM
Next, check the wire to the temp sender. Sounds loose if it changes, or the wire has a break in it near the terminal. Could still be a bad sender, but the wiring should be checked before replacing anything.
Old 09-07-2004, 11:09 AM
PeteS's Avatar
As always, Jim, you are a lifesaver. The sender, is that the unit located in the thermostat hole on the top of the block, drivers side? The wiring looked good coming from there, if I was checking the right place. Thanks again.
Old 09-07-2004, 11:39 AM
That should be it. It's about the same size(but not as long) as a spark plug with a tan or tan/black wire on it. Turn the key on and see if wiggling the wire changes anything.
Old 09-07-2004, 11:43 AM
PeteS's Avatar
Great, we are on the same page. I tried wigglingt he wire with the ignition on, and didn't see any changes in the needle on the gauge. Possible bad sending unit?
Like I said, the gauge jumps to 130 during start up and then slowly falls down to around 100 after a few minutes. Thanks again.
Old 09-07-2004, 11:46 AM
PeteS's Avatar
If this is the right piece, looks like it's only $9.00 at DIM:
http://skidim.com/prodinfo.asp?numbe...item=4&mitem=6
Old 09-07-2004, 05:08 PM
acurtis_ttu
Just replace the sending unit. It is very cheap to replace, and only takes a few minutes. Make sure you don't over torque.
Old 09-07-2004, 05:13 PM
PeteS's Avatar
Thanks for the advice. Does the above sending unit look like the right part?
Old 09-08-2004, 09:25 AM
Hoff1's Avatar
Hoff1 Hoff1 is offline
Boat: MasterCraft, Maristar 210 openbow, 1990, 351W
Donít know how long you have had your boat, but mine had similar issues when I purchased it. I tried replacing the gage a couple of times, with no luck. I pulled the sending unit out, and tested it with a hair dryer. Thing worked without any issues. I was a little confused until I went to replace the thermostat. Found that the previous jacka$$, I mean owner, had removed the thermostat completely. Just a thought.
Old 09-08-2004, 09:31 AM
PeteS's Avatar
Now that's a classic move, Hoff. Sorry to hear that, it makes me cringe to think that my boat actually may be running at 100 degrees.
I'll try the hair dryer trick. Just pull the sending unit, aim the hair dryer at the bottom, heat it up, and watch the temp gauge with the key on? How long do I have with the key on and the boat not running before I fry my electronic ignition?
Last question, and I know, I know, it's a dumb one. Where are both thermostats located to make sure my previous owner didn't do the same thing yours did? Thanks a million.
