Old 07-28-2013, 08:05 PM
kevkan kevkan is offline
Boat: Mastercraft 2008 X-1
I owned an '85 S&S for 24 years and never even upgraded to electronic ignition. In that period, I think I had the carb rebuilt twice. Sure, it could be a little finicky at start, especially if the weather was cool or damp. I just let it run for a bit on the trailer while launching, or started it before untying dock lines. Never a big enough hassle to justify spending over $1500, and probably making the engine much harder to diagnose.
I do think it is very important to find a good mechanic, and especially one that will lake test the boat.
Old 07-28-2013, 08:17 PM
John 3:16-18
Old 08-06-2013, 09:51 AM
kjohnson's Avatar
kjohnson kjohnson is offline
TT Hero
Boat: 1991 Prostar 190
Carb
How much warm-up time are you dealing with? The choke is only on for 90 seconds.
It seems like a minute or two. It usually cuts off once or twice at first and then I get it set at about 1200 rpms and warm it up. Then it runs fine. Oh, I did install a new electric choke as the old one was not working and it did not seem to make any difference.
Love my boat, hate my trailer.
Old 08-06-2013, 10:00 AM
I would look for a problem that is worse at cold start like a vacuum leak at the base of the carb. Could be your idle mixture is on the lean side. How long since your carb has been rebuilt?
Old 08-06-2013, 10:07 AM
kjohnson's Avatar
TT Hero
Long time.
Old 08-06-2013, 10:11 AM
Originally Posted by kjohnson View Post
Long time.
I would check for a vacuum leak by spraying carb cleaner around the base of the carb/base plate while it is idling. If the idle speed increases, you found your leak. Of course use care while doing this, though I have never had a problem and I have done this literally hundreds of times.
Old 08-06-2013, 10:27 AM
kjohnson's Avatar
TT Hero
Carb
How do you know I have a leak?
Old 08-06-2013, 10:35 AM
Don't know for sure. If an engine is stalling during warm-up, it is usually because of a lean condition. As the engine and carb warm up from operation, the metal expands and seals small gaps caused by dry gaskets that shrink over time and leak when the engine is cold.
Air entering through a base gasket leak will lean out the mixture. The carb can't add more fuel because the leak is below the carb and may cause stalling until the engine warms up.
Old 08-06-2013, 10:45 AM
http://www.holley.com/types/Terminat...%20Systems.asp
Someting like that wouldnt work huh?
Old 08-06-2013, 10:50 AM
It doesn't say that it is marine approved. It may be, but the cost is prohibitive.
