Old 07-25-2013, 02:46 PM
VP46's Avatar
VP46 VP46 is offline
X-2 Garage Door Height?
Helping a buddy buy his next boat.... first thing is first which year x-2 to purchase that will fit? He prefers to not go in with a partner as such older x-2's better but if he has to rebuild a garage door he might just go newer to save the hassel. How new does he have to go?
04 and older x-2/205v:
I know 04 and older x-2/205v with zero flex require 82 and 1/8" at the VERY minimum (best at 83 but 82 1/8 will fit)....so that means at his current door height of 80in it will NEVER fit.
I don't think this is posted anywhere so hoping someone can help us out.
2005 X-2:
fit in a 80in high garage door?
2006 x2:
fit under an 80in door?
2007 or Newer?
Old 07-25-2013, 03:29 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
06 and newer are the pickle fork version and they are supposed to fit a 7' door. But it's tight from everything I've read here.
Old 07-25-2013, 04:42 PM
VP46's Avatar
Thank you! Thats exactly what I needed to know!
Old 08-05-2013, 05:22 AM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
06 X2 will not fit under a 7' Door unless you disconnect the rear tower legs and lay one over the side of the boat and one inside the boat.
I attach a nylon strap to the port side wakeboard tower from the tow point and pick the leg up and set it over the port side. Strap holds it on the boat.
With the Starboard leg inside the boat (You have to remove the seat behind the driver) and the port leg over the boat and your front legs forward you can get it in out of a garage.
I've been doing it for 7 years, not my favorite thing to do. 07 boats can get in the garage without that manipulation I've been told.
2006 Maristar 200VRS MCX
KGB Ballast and all the works! (Once upon a time)
Tow Veh: 2010 Toyota Tundra
Bike: 2009 HD Street Glide
Beer:Ballast Point IPA's
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 08-05-2013, 01:21 PM
Indyxc Indyxc is offline
Boat: 2006 Mastercraft X2
I concur with Chief.
My 06 X2 will not fit into a 7 foot garage door. Mine is about 6 feet 10 inches, and when I tried it, it was off by about 10 inches, so even a 8 foot garage door might be tight.
So I also, lay the rear tower hoop onto the sunpad, and remove the hand screws hold it to the hull. I then completely remove the rear hoop and put the boat in the garage. The front legs that fold foward clear the 7 foot door no problem.
I only do that once a year (since I live on the lake). Multiple times a year would be a headache.
Old 09-12-2013, 08:42 AM
BudmanV24 BudmanV24 is offline
Boat: 2006 MasterCraft XStar
I have an 06 X1 with single axle trailer. As long as I rotate the board racks 90 degrees it fits in my 7ft door. Keep in mind the approach has a lot to do with it. Does the driveway slope up to the garage, down to the garage, is there a lip, or dip. All affect how high the boat will be on its approach.
Old 09-13-2013, 04:15 PM
SJ.'s Avatar
SJ. SJ. is offline
Boat: 2008 X2
I have an 08 X2 single axle with 8' doors. It makes it in just fine with the tower folded to the sun pad, but I can't see it working on a 7'.
Old 06-15-2014, 01:34 AM
doubleAboys doubleAboys is offline
Boat: '04 MCX2
04MCX2 Fits Like a Glove
Here's a pic of my 04MCX2 in my 2 car garage. Thankfully I have air suspension on my rig so I can lower the truck by 6 inches which gets me in but barely, then I tuck it in all the way against the side wall and the back wall and can still fit a car next to it. I've gotten it down to about a 30 minute process to pull out and put to bed. Saves me a ton of money on storage costs.
