Old 07-22-2013, 08:02 PM
Originally Posted by cruiser View Post
I did a lot of work on 30ft. plus chris crafts years ago with the same problems. If the shaft is straight, prop is straight and balanced and the key slot and key way are cut to proper depth. By this i mean put the prop on without the key in place and mark with a black marker, then remove the prop, install the key and replace the prop. It should go back on to the mark. If it does not you have to mark with hi-spot blue and scrape it in. If the prop does not go on to the same location, under load you can get a vibration from what we used to call Prop Wiggle.
Interesting write up - I'll have to check this out...
Old 07-22-2013, 08:36 PM
AZDave's Avatar
AZDave AZDave is offline
Boat: 1993 Stars & Stripes Prostar 190 351 285 hp
Yes. It looks like you unbolt it and pry it apart, but there must be more to it.
Old 07-23-2013, 08:36 PM
AZDave's Avatar
Prop shaft ok. Coupler alignment at .010, tolerance .003 from manual. Slight vibration makes sense. Taking it to MC to adjust. Thanks for the help, I learned a lot...again
Old 07-23-2013, 08:47 PM
John 3:16-18
Old 07-23-2013, 10:35 PM
AZDave's Avatar
Acme 4 blade. CNC machined. When I installed it 7 years ago it helped smooth it out. When I put a new bushing on the raw water pump a few years back, that also helped. I think once the motor is aligned it should be pretty good.
Old 07-24-2013, 06:16 PM
John 3:16-18
Old 07-24-2013, 06:21 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Misalignment will not cause vibration... it will dampen it. It will, however, cause your strut bushings to wear unevenly- which will cause a (greater) vibration once everything is aligned properly.
Old 07-27-2013, 05:46 PM
AZDave's Avatar
We will soon see. The boat was off about .010". Prop turns a little smoother now by hand. I guess if the vibration increases, the bushing will be the last thing to do. It is not like it ever had a severe vibration.
Old 07-27-2013, 05:54 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Good video on shaft-engine alignement...
http://www.youtube.com/watch?v=3_w0LvD6gEc
Keep skiing!!!
Old 07-29-2013, 03:42 PM
AZDave's Avatar
Vibrating less following shaft to engine alignment. Very happy with boat operation now. Dealer said it was off. Took 20 years to need adjusting. I wish you could buy a brand new boat as simple and user friendly as these old ones. Hmmm, sort of like cars. Bells and whistles come with a price.
