Old 07-22-2013, 01:11 PM
JGWIN55 JGWIN55 is offline
Boat: 2010 Mastercraft X25
X25 with Plug n Play
Finally got my surf setup installed in my 2010 X-25. hooked up a 750 in each trunk to the Plug n' play system plus an 1100 bag on the surf side. turned out pretty nice. I'd read mixed reviews about the plug n play, but worked fine. It was kinda slow to fill but convience of flipping a switch was worth it. If monitoring the bag to vent is my biggest problem I think i'll make it. These pics are this setup with a driver and spotter only. Name:  mattwake.jpg
Old 07-22-2013, 01:14 PM
last pic seemed to not work well....heres another tryName:  mowake2.jpg
Old 07-22-2013, 05:03 PM
Nick911's Avatar
Nick911 Nick911 is offline
How do you fit 750's back there?
Old 07-23-2013, 04:40 PM
They actually fit fine. I didnt fill them up ALL the way tight as to not get against any possibly damaging sharp corners. Also in the Starboard side where the seacock water strainer apparatus is there is a pipe clamp in a bad spot. I wrapped that with some foam to protect.
Surprisingly they fit really well. Not sure I would go too much larger in those spaces, but the 750s fit well.
Old 07-24-2013, 02:40 AM
Stefan's Avatar
Stefan Stefan is offline
Depending on your DIY capabilities you can either loosen the pipe clamp and turn it or move the whole the raw water strainer to the transmission compartment, that's what I did just to find out later that MC itself does it on some '13 Models I've seen...
If You Find To Many Capitals You Can Keep Them...I'm German
surf, x25
