Old 07-04-2013, 12:50 PM
BoulderX45 BoulderX45 is offline
Boat: MC, X-45, 2006, LQ9
Ballast Pump/switch/wring Issue
Help? I had a ballast pump that wouldn't come on to empty all the time. I would have to toggle between fill and empty to get the pump to come on to empty. I never had a problem with getting it to come on to fill. So, I thought it was a bad motor on the pump that was binding up. So, I swapped the KGB pump with the STBD pump and got the same issue with the different pump. So, I thought its got to be the switch. So, I replaced the switch and still same issue. Any suggestions on where I start to look at the wiring?
Thanks,
BoulderX45
Old 07-04-2013, 03:46 PM
snork snork is offline
Boat: 07 xstar
Green impellers? sounds like you have an issue with the pump not priming
Old 07-05-2013, 08:40 AM
Boat: No Boat
I think in 06 the factory impellers were still the black ones. I would check to make sure and if you don't have the green impellers then that is most likely your problem.
www.wakemakers.com has them.
Old 07-05-2013, 01:28 PM
They have the green impellers. It's the actual motor not coming on.
Old 07-05-2013, 02:02 PM
73blue 73blue is offline
Boat: 2004 X-10
You could unplug the wire from the pump and turn the switch on. Take a test light and see if you are getting power through the wire. If not, its most likely a broken wire.
Old 07-05-2013, 03:37 PM
Drake2785's Avatar
Drake2785 Drake2785 is offline
Boat: MasterCraft X2
Unplug the pump see if you are getting 12v back to the pump if you are go back to the switch. Could be a bad switch or breaker.
Old 07-05-2013, 08:25 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
I have the same issue with a Johnson I installed. It happens to me if i empty the boat and then the boat sits for some time. The veins on the impellar actually stick so I have to toggle back and forth to break it free. The pump doesn't seem like it comes on, but it does. It's just the impeller stuck and breaks free after essentially "jiggling" it with the switch. So I took Jason's advice from Wakemakers. After you are fully empty cycle the switch to fill for a brief second to get the veins going the proper direction before you store it. I haven't had an issue since using this method.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 07-05-2013, 11:37 PM
Boat: No Boat
Well then, you know it must be the empty wire is broken at some point so it should be pretty easy to find out where that is happening.
You've switch pumps, you've switch switches, you have good impellers so it should be pretty easy to find it from here.
Put a volt meter on the plug at the pump end and check for voltage with the switch in the empty position. If you have nothing then check for voltage at the switch in the empty positions. The only thing between the switch and the pump is the circuit breaker and the wire.
Old 07-20-2013, 10:46 PM
Drake2785's Avatar
Size:  61.5 KBName:  ImageUploadedByTapatalk1374371079.668241.jpg
This is what happens when you have a fuel pump short out. All you can do is pray you get it put out before it burns through the tank.
Old 07-22-2013, 12:13 PM
bjw444 bjw444 is offline
Boat: nautique and hopefully xstar soon
At that point you abandon ship and collect the insurance money... Will never be the same, hate to say it. Resale value especially will suffer.
