  #51
Old 08-26-2013, 01:47 PM
College Kid's Avatar
College Kid College Kid is offline
Boat: 93 Prostar 190
I just traced the purple wires from the ignition over to this, it is behind the gauges. Could that be the trouble? It has the name Mallory on it.
Old 08-26-2013, 02:15 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
The pic is of the audible alarm circuit board, they do go out but will not cause the engine not to start. As far as voltage at coil 8-ish volts is where it needs to be if you have a ballast resistor, it will not have a resistor behind the dash.
Here is a basic 351w engine diagram, yours should be similiar.
/spôrk/
Old 08-26-2013, 02:21 PM
Thanks,
If no resistor behind the dash, then I don't think I have one.
So I should be getting more than 8 to the coil. Any guess as to where I could be losing volts?
Old 08-26-2013, 02:56 PM
You probably need to start using an ohmmeter to check resistance on connections.
Old 08-26-2013, 03:03 PM
Spork's Avatar
Boat: Sporkcraft
Originally Posted by College Kid View Post
Thanks,
^What he said..
How many volts do you have on the purple wire going to the choke?
/spôrk/
Old 08-26-2013, 03:08 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
Originally Posted by [email protected] View Post
^What he said..
good call they may be swapped?
I hate electrical
Old 05-14-2014, 04:36 PM
Back into this project once again. And have a quick question. My mechanic friend who is helping me thinks it could be a crank sensor not lining up right with the new fly wheel. I didn't think there was any sensor on these old engines. Just the temp guage.
Do the engines have a crank sensor and if so, where would it be located?
Old 05-14-2014, 07:13 PM
Spork's Avatar
Boat: Sporkcraft
Your engine does not have a crank sensor.
/spôrk/
Old 05-14-2014, 10:46 PM
Thanks J
I will work on the electrical at the dash then.
Old 05-15-2014, 12:03 AM
Spork's Avatar
Boat: Sporkcraft
Thanks J
Do the gauges work? Have you checked for voltage at the coil? At the electronic ignition? What kind of voltage do you have on the purple wire going to the electronic choke with key on? If your getting voltage I might suspect the EI may have failed.
/spôrk/
