Old 07-21-2013, 11:24 AM
College Kid's Avatar
College Kid College Kid is offline
Boat: 93 Prostar 190
First Start of the year, ran but then stopped. (Flywheel needs replacement)
Hooked everything back up, put in plugs etc.
After a few pumps of the throttle the engine fired right up. There was some pretty bad belt whine and realized I had not re tightened the belt via the alternator.
I tighten it up, go to start the boat, has a bit more trouble but fires up.
Let it run for about 1 min, shut it down to add some belt dressing, then go to re start and won't fire up.
I can hear the engine spinning, but the pulleys don't spin or run at all. Almost seems like they aren't connected.
Looking for thoughts and ideas to check??? I am headed back out to try it again with the belt looser
Old 07-21-2013, 11:40 AM
Dynamite Spike's Avatar
Dynamite Spike Dynamite Spike is offline
Boat: 1996 Prostar 205
Sounds like a seized water pump or alternator. Take the belt off and see if you can turn the pulleys by hand
Old 07-21-2013, 11:51 AM
Loosen belt, it didn't help
Alt spins by hand as does the chrome pulley (don't know the name of it). I have removed the water pump and it spins easily.
I put a wrench on the lowest pulley (wish I knew the names of these things) It turns but takes A LOT of force to move it.
As I have never manually turned over an engine I am not really sure how tough it should be to move.
Thoughts?
Old 07-21-2013, 12:38 PM
If engine turns the pulley connected to harmonic drives alternator and water pump. Shoot some video and post on youtube and give us a link... don't even have to start just let it turn for a second or 2.
Old 07-21-2013, 01:02 PM
Will do,
I put it all back together and gave it a crank and it turned. Didn't start but the pulleys do all spin.
researching I found this thread and decided to pull the starter to see what's going on there. I noticed a lot of metal shavings that look new.
I'll grab some pictures, and maybe a video if I can figure out how to upload it.
keep the comments coming.
Old 07-21-2013, 01:11 PM
So some pictures of the flywheel and starter.
Could this be an issue with the starter not able to engage the fly wheel?
The starter spins, but doesn't seem to be engaging the fly wheel, or is it engaged all the the time?
Old 07-21-2013, 01:31 PM
I cleaned up the shavings and put it all together, now the starter only clicks?
Thought maybe the battery might have lost power so went to remove the leads, and noticed the positive terminal and wire were very hot. this might be un related but seemed odd to me.
for now I have thrown the battery on the charger to make sure it is good to go. Dash guage was reading around 9 or so.
Thinking I may need to rebuild the starter now?
Any other thoughts?
Old 07-21-2013, 01:32 PM
jhall0711's Avatar
jhall0711 jhall0711 is offline
Boat: None
The noise your hearing "when the pulleys are not moving" is that starter turning without turning over the motor. The flywheel teeth appear to be stripped pretty badly in that one spot. By turning the motor by hand IE moving the big pulley at the bottom that is hard to turn, you can move it to a good part of the flywheel to get the starter to engage again; but that is only a temporary fix.
Old 07-21-2013, 01:35 PM
So what your saying is I need a new flywheel?
Old 07-21-2013, 01:39 PM
Yes, -- look like it's time for a new flywheel - change the damper plate while you at it... you also myigh be able to get a machine shop to install a ring... but I am not an expert... This is where the dead engines help out with parts... IMO
