Old 07-19-2013, 01:53 AM
Nickracer9 Nickracer9 is offline
Boat: 04 mastercraft xstar
Running four batteries, best way to wire them up?
Currently have 2 northstar group 31 Agm batteries set up with the standard guest 1,2,1+2 battery selector isolator(whatever you call it) with a 2 bank charger wired up to each one of them. Looking to add two more to my boat and want to know what's the best way to wire these guys in. I was thinking about two banks with both batteries added in parallel but not sure, can anyone lead me in the right direction? Looking to power 4 JL MHD amps. Thanks,Nick.
Old 07-19-2013, 06:30 AM
timvan's Avatar
timvan timvan is offline
Boat: none
One battery for starter, 3 for the stereo. Wire the 3 parallel.
2002 Maristar 230 VRS
Old 07-19-2013, 03:32 PM
XStar08's Avatar
XStar08 XStar08 is offline
Boat: MasterCraft XStar, 08, LY6; MasterCraft ProStar 190, 91, Ford Mustang;
You could ad a few more and use them as ballast as well!
Old 07-19-2013, 04:02 PM
I know 80lbs a piece!
Old 07-19-2013, 04:08 PM
I thought about running the one for a starter and the 3 for stereo but that leaves 10amps of charging going to the starter battery and the other 3 having to share 10amps on the second bank. Would that even charge them overnight full after a good 50-60% drain on them? Thanks guys.
Old 08-07-2013, 10:28 PM
PremierPOWER PremierPOWER is offline
Boat: Lots
It's best to charge a battery isolated otherwise when the first battery in a paralleled set is 100% the charger will go into float mode even if the other is less than 100% (assuming its an automatic smart charger). It would behest to do one battery for starter and 3 for stereo with an isolation switch between parallels. Have two two bank chargers and the switches That way you can break the parallel with the switches in the off position and each battery will have its own bank for charging. This is even more critical if using different brand and age batteries for the paralleled 3 but it would be best to have those 3 all the same battery and same age. Of course your next problem will be ruining a stock alternator
- 1996 Donzi 22 Classic Blackhawk Limited Edition w/ 500hp Mercruiser 502
- 2001 Sea-Ray 240 Sundeck w/ Mercruiser 383
- 2005 Formula 382 FasTECH w/ Twin Mercury Racing HP600SCi
- 2008 Donzi 43 ZR w/ Triple Mercury Racing HP700SCi
- 2009 Meridian 441 Sedan Bridge w/ Twin Mercruiser Cummins 480
- 2014 Regal 27 FasDeck RX w/ Mercruiser 8.2 Mag
- 2016 Nor-Tech 390 CC w/ triple Mercury 350's
Old 08-09-2013, 09:47 AM
Boat: 2014 X-25 6.2 Ilmore
Not sure how much power your amps will be drawing but I had to eventually upgrade my alternator. I was adding batteries, but the charging just wouldn't keep up in my case.
