Old 07-31-2013, 02:57 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
94 TBI intermittent high idle
Been chasing that one for a while.When stopping at the end of the course or to change skier when i start back the engine,sometimes(once every 3-4 stops) idle is high most time around 720 rpm and once in a while as high as 1100 rpm.Reving the engine in neutral won t do nothing and the throttle linkage is fine too when this happen.Only stopping,waiting a few seconds and starting again will correct problem.Just put back my old IAC as this was happening more with the new one.Boat run like a champ other then that.
No codes store.
Checked ECT resistance cold and with 140 hot water.Right on the specs.
Replaced IAC,problem persist...
Anything else related to a intermittent high idle i can check
T.I.A.
Andre
Keep skiing!!!
Old 07-31-2013, 03:05 PM
_fng_'s Avatar
_fng_ _fng_ is offline
Boat: Prostar 205
My boat does the same thing and the throttle position sensor and IAC are always suggested in threads like this. I'm not sure if there is a diagnostic test for these without replacing them but that would be nice to know.
Jim N posted previous "Find out if the parts are actually bad before replacing them. The TPS can be checked with a multi-meter.
Remove the throttle cable from the throttle lever- if it stays at normal idle, it's definitely not the IAC and TPS. You need no tools to disconnect the throttle cable." thread I found it on is below
http://www.mastercraft.com/teamtalk/...ad.php?t=37171
Old 07-31-2013, 03:16 PM
André's Avatar
Forgot to add ,TPS was change last year chasing that one too.
Since there is no codes,i had to try something.TPS,IAC didnt solve it and it s not the linkage,already checked that...
Keep skiing!!!
Old 07-31-2013, 05:46 PM
_fng_'s Avatar
Boat: Prostar 205
Did you buy a regular 350 TBI TPS? I'm thinking about throwing money at my problem as some people say it helps and people have said they got them at local stores but I'm not sure.
Old 07-31-2013, 08:27 PM
André's Avatar
Yes.Got it from NAPA.Don t have part number,sorry!
Keep skiing!!!
Old 07-31-2013, 08:43 PM
Remove the throttle linkage from the throttle body and see if it settles down to the correct idle speed.
Old 07-31-2013, 08:46 PM
André's Avatar
Already checked and remove linkage and Perfect Pass.Throttle return freely to rest...
Only way to return to a normal idle (and still a bit high at 650-660.Normal for my boat was always 610-620 rpm) is to shut down and restart ...
Keep skiing!!!
Old 08-03-2013, 07:51 AM
bret's Avatar
bret bret is offline
Boat: Prostar 190, 1993, Anniversary Limited.
Is your throttle linkage hitting the transmission cable upon return...this was my case at the end of the course after a run. I had my trans cable tie wrapped by the forward lifting eye and the perfect pass linkage was just barely touching, causing me a 1100 rpm idle. cut the tie wrap and let the cable go, it moved to the right a bit and now all is well.
Old 08-03-2013, 09:22 AM
CruisinGA's Avatar
Boat: '01 X9 330HP
Have you checked/cleaned your throttle body?
Sometimes oily deposits can build up and prevent the throttle plate from closing all the way.
Bailey
'02 X-9
Lake Blue Ridge
Old 08-03-2013, 10:38 AM
André's Avatar
Thanks guys.Will triple check my linkage and throttle body!
But the reason i don t think it is mechanical is that turning the engine off and starting again will clear the high idle and return to 620 to 660 rpm depending and i can visually check that the linkage is returning to his rest position.Can t move it by hand to close it more.
Thanks !
Keep skiing!!!
