Old 07-30-2013, 04:45 PM
Originally Posted by Ski-me View Post
Sorry about the treadjack djr.....
Jim, I've told her to video it on her phone when it happens again. Then at least a mechanic can actually hear what it's doing.
When it occured, I openned the engine cover to watch it continue to not start. All of these problems are still occuring while the engine cover is wide open.....blower also being used prior to starting as well.
Carb, or EFI? If carb, it definitely could be vapor lock- can you verify that gas is going into the intake? With TBI, this is as easy as it it had a carb. If you see no gas being delivered, make sure the pump is activating when the key is turned to ON.
Has any work been done on the engine, other than oil changes and minor stuff like that?
Old 07-30-2013, 05:26 PM
Ski-me's Avatar
Ski-me Ski-me is offline
It's a EFI, Mercury Scorpion 330HP engine. I think that's sequential injection, not TBI if I recall.
I'll check with her on the fuel pump turning on with key before start-up.
Nothing major on engine other than a few minor tune-up parts (plug, cap, rotor, fuel filter). However he did install a new alternator and possibly a new grounding wire......however, it was still behaving this way prior to his repairs.
- Jeff
1994 205, LT1
Old 07-30-2013, 05:38 PM
Someone needs to verify fuel pressure and quality, as well as spark, when it won't start. I have seen ground wires that were loose/broken and when the engine compartment temperature was high, the wires relaxed, breaking contact with the block and when it cooled, it was fine. Could be a connector that's doing the same thing.
Old 07-30-2013, 05:43 PM
Ski-me's Avatar
Thanks Jim for the help. I just wish the boat was in front of me to get this thing resolved. I helped her pick the boat out so I feel slightly responsible that it's not performing 100%.
- Jeff
1994 205, LT1
Old 07-30-2013, 08:22 PM
I don't know why you would feel responsible for the problems- Cobalt is a very good boat although I'm not as familiar with Mercruiser as I was.
You could call the Mercruiser tech support department, too- they'll want the engine and transmission serial numbers (inboard, right?), or engine, gimbal, outdrive serial numbers if it's a stern drive.
Old 06-13-2017, 10:14 AM
Zroc Zroc is offline
Boat: 2010 X-Star
Hey I know this is an old thread but my 10 Xstar is having what sounds like a very similar issue. MCX and ZF tranny. Seems to slip out of gear when given gas. Did it a couple times and was able to nurse it back to the doc. At the dealer now and say they have checked linkages but couldn't replicate on the trailer. Needed to lake test to put it under load. I'm curious what the couplet in the transmission costed and if they had to pull it to rebuild. Thanks
Old 06-13-2017, 10:43 AM
They really thought they could test this on the trailer?
Old 06-13-2017, 03:09 PM
coupler is cheap - which trans model?
Old 06-14-2017, 01:18 AM
Boat: 2010 X-Star
Not sure but I think 45 from what I can remember. I'm outa town right now but can check over the weekend. Does that sound right. They said they thought it may be a transmission pump.
Old 06-20-2017, 11:47 PM
Boat: 2010 X-Star
Shop says it's the transmission. From what they can tell overheating and nothing engaging. (Weird thing is the tranny ran fine until it got a flush and new filter 5 hours ago) it's a Hurth 63 IV. Quoted at $3400 for a new transmission and after the swap the estimate is 7k.
throttle position sensor, transmission
