Old 07-15-2013, 03:15 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Perfect Pass shuts off intermittently
2004 Maristar. I installed Perfect Pass Wakeboard Pro and it's always worked well. At the very end of last year I noted that periodically while running it would beep and shut off, then restart and it's still doing it this year. I did check the servo tension, checked and cleaned all the connections both to the Perfect Pass brain box and the plug at the main wiring harness. Grounds on the bus under the dash all look good- but I tightened them up anyway. Battery connections are good. Voltage is good. No other gauge issues when the PP cycles, just the PP display. All other electrical stuff seems to be working fine.
Any Perfect Pass gurus out there ever deal with this problem?
'04 MariStar 230VRS/MCX
