Old 07-10-2013, 01:55 PM
alfie623's Avatar
alfie623 alfie623 is offline
Boat: Mastercraft, Maristar, 1999, 330 LTR
Blower motor in '99 Maristar
My blower is tripping the dash mounted breaker and doesn't seem to be functioning. Does anyone know where is it? I can't seem to find it; I checked near the fuel tank and looked around in the engine compartment.
Old 07-10-2013, 06:02 PM
mdskier mdskier is offline
Boat: 1999 Maristar 210 w/Tower
I have the same boat and just replaced my blower. It is mounted directly below the engine on the stringers in the engine compartment. I had to remove the lift actuator that raises the engine cover. Then drop the divider and the blower was right there. A single bolt (9/16" ?) holds the bracket down and a couple of small bolts hold the blower on the bracket. The Attwood Turbo 3000 blower on the Overton site was a direct replacement. I did have to cut off the power connector from the original and solder it to the wires on the Attwood blower.
Old 07-13-2013, 12:59 PM
alfie623's Avatar
Thanks for the info!!
Old 07-13-2013, 01:01 PM
Its usually bolted to stringer starboard side that I have seen - or opposite side from Trans cooler... but I could be generalizing..
