Old 07-09-2013, 11:04 PM
PoqKen PoqKen is offline
Boat: 2006 X30, 2014 X30
Raw Water Strainer Gaskets / O-rings
Does anyone know the dimensions of the very small o-ring/gasket that is used in the cover (under the thumb screw) on the newer raw water strainers. I think the strainer is built by Marelon and is used in 2013 and 2014 boats. You can buy a o-ring and gasket kit containing all three gaskets/o-rings for about $25 dollars, but I only need the very small o-ring under the cover thumbscrew that should cost a couple bucks and be available at Lowe's or similar hardware stores.
