Old 07-09-2013, 09:11 AM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
Trailer bouncing on right side
This past Saturday my brother was following me home from the lake. He said that my right side of my trailer was bouncing a lot more than the left side. I had noticed it before from the truck, but was never concerned enough to investigate. From behind, he said the difference was pretty drastic. Single axle trailer. We looked at the springs, but could not find any obvious defects. I have heard of the mid-90s trailer leafs breaking before, dropping the fender down on the tire.
Any ideas? Is the bouncing right side about to go? Is the left side already broken and should be where I am focusing my attention?
One note, I put new trailer tires on last spring before driving it home after purchase. Maxxis tires. Same on both sides and I check tire pressure often and it is usually the same side to side and the tires donít seem to leak over time. There are no obvious differences in the tires.
1996 Prostar 205 LT-1
Old 07-09-2013, 09:15 AM
madcityskier's Avatar
Lose weights on one, new it's out of balance? If one spring had been replaced there could be a difference. Maybe as simple as tire pressure. Did you leave a filled fat sac on one side?
Old 07-09-2013, 09:26 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Take the tires in and get them spin balanced? At that time they can check to make sure they are both round. Out-of-round tires aren't that uncommon, especially trailer tires. You can check leaf spring quality by measuring the distance between tire and fender. If they're both roughly equal then that's not likely to be the culprit.
I'd bet on tire/wheel out of balance or out-of-round.
'04 MariStar 230VRS/MCX
Old 07-09-2013, 09:33 AM
Double D's Avatar
Double D Double D is offline
Or your tire could have a bad belt or a bubble in it ready to pop. That happened to me and I had one heck of a shake back there before it blew.
1994 MasterCraft ProStar 205
275 HP 350 Chevy Indmar
Monster Tower & PerfectPass
Old 07-09-2013, 10:16 AM
Have a look at the wheel bearings. When they are loose, it is not uncommon to bounce or track poorly.
Old 07-09-2013, 12:45 PM
johnnye23's Avatar
johnnye23 johnnye23 is offline
Boat: 1979 Stars n Stripes
I would check air pressure,then swap wheels/tires side to side and see if it follows.
Old 07-09-2013, 01:40 PM
jakethebt's Avatar
Thanks for all the ideas. I will try and switch tires and see if it follows. I can do that myself and not have to take it anywhere.
No ballast, no uneven weight. Tires are running at same pressure. Only difference I can think of on right to left balance would be the spare tire in the front on the right side.
The bouncing is mainly in reaction to bumps. It tracks fine, but when you hit a bump, the right side seems to bounce more. Kind of makes me think springs?
I will check the bearings too. Just looking for looseness in the bearings? Loose gland nut? Feel for wobble in the brearing or grinding?
Old 07-09-2013, 01:50 PM
Raise and support the trailer axle. Grab tire at top and bottom and look for play. Do the same thing on side to side. Also turn the wheel and listen/feel for noise and/or roughness.
If you ever hear of someone losing a bearing buddy while on the road, you can count on it being the result of a bad wheel bearing.
Old 07-11-2013, 12:50 AM
sp00ky's Avatar
sp00ky sp00ky is offline
Boat: 1994 prostar 205
Same thing happened to me right before sidewall exploded.
This forum is amazing with quality people.: I did not think i'd ever own an Inboard. Now I finally have a gorgeous 94 205 I am glad I have ya'll backing me up.
Old 07-11-2013, 10:56 AM
Brakes seized on that side?
