Old 07-08-2013, 02:22 PM
Master Earl Craft Master Earl Craft is offline
Boat: MasterCraft Prostar 190 1993 351W HO
chirscraftmatt1976 - Your note about the new carb, "I'm probably going to replace with a different carb anyway. This one ***," didn't show the model number. Are you refering to the Holley 4150. I found a post from 2006 which had a couple reccomendatons... see below.
There are two options that will work on your application. The first is part #0-80559 (Holley 4150, 600CFM). This is a 600 CFM unit that should be plenty big for a 285 horsepower application, and will make your boat run like a FI boat.
The second option is part #0-9015-1 (4160 750 CFM). This is the 750 CFM unit, which is probably overkill, unless you have dreams of swapping cams/heads/etc, to create a high performance gas-guzzler.
You can find these carbs Vic Hubbard's marine shop for $449: https://vichubbard.com/shop/product.php?productid=61964
Old 07-08-2013, 03:27 PM
Originally Posted by MI_Corey View Post
My dad has the same boat and had the same issue. After fighting it a couple years he gave up and bought a new carb. That was about five years ago and no problems since.
What new carb did he get?
Old 06-23-2014, 05:51 PM
Still Issues - one year later
I made the leap and replaced the 4010 with a 4160. Still have the issue with hard start when warm. I may have a little work to do yet setting the floats and idle mix, but cannot foresee that making enough of a difference to solve this. Does anyone believe that perhaps it is electrical? Should I replace plugs and wires? Is my coil getting too hot and not efficiently getting enough juice to the plugs? Do I need a new distributor?
If I knew what I could get for my boat, I'd sell is and look for a '94 with EFI.
Old 06-23-2014, 08:01 PM
Jerseydave's Avatar
TT Hero
[quote=TRBenj;954807]Anyone who thinks they need to "pump the throttle" to get a carb'd engine to start when warm should try the trick described above. Same goes for anyone who thinks their carbureted boat suffers from "heat soak". If it works, then the engine is flooded and needs air, not gas- and every time you pump the throttle you add both! Just open the throttle once and it'll start a little easier until you have a chance to fix the problem.
In the above described scenario, pop the flame arrestor off the carb and take a look down the throat to see whats happening. Check it at idle (engine running) and directly after shut down. Chances are that you will see fuel dripping. Fuel should not be dripping from the boosters while at idle, and should not be dripping at all with the engine off. Dripping fuel is the result of either a)float set too high or b)needle and seat issues. Both will allow the bowl to fill past the point where it should, and the excess fuel will end up dripping in the main body of the carb, past the butterflies and puddle in the intake manifold. EI, flood the engine.
^Check the carb for dripping again while it's hot and idling, and also when you shut it off. There should be no gas dripping from the boosters.
If that looks good, start with basics on the electrical system. New points and condenser, set the dwell (with a dwell meter) and the timing. A coil can go bad and get hotter than normal causing a problem with hot starting, so don't discount that either. I think a new coil is pretty cheap, might be worth getting one. Check your ballast resistor too if you have one. Also a cheap part to replace.
I was njskier on here.
Old 06-23-2014, 11:28 PM
madcityskier's Avatar
Chriscraftmatt1976 stopped hanging out here. I believe he ended up replacing the fuel lines and the overflow valve. That seems to have made a big difference. His sat for a couple ears with 10% ethanol in it, and the fuel lines were very gummy. Ran great 2 weeks back when he took me out.
Old 06-24-2014, 12:03 AM
You could have some resistance in the electrical system preventing battery voltage from being present at the coil (less the ballast resistor). Check your voltage at the + side of the coil with the key on. Also check voltage at the connection at the ballast resistor. Also check cranking voltage at the coil. Something as simple as a battery cable with high resistance can cause this. I just replaced my battery cables for this reason.
Old 06-24-2014, 08:33 AM
No points, condenser, or ballast resistor. Replaced with Electronic Ignition. The marina also replaced the coil before I started with the carburetor.
