Old 07-03-2013, 10:31 PM
georgea0731's Avatar
georgea0731 georgea0731 is offline
Boat: MC, 35th Anniversary Edition, 03 Stars & Stripes
SUV fuse blows with 12v transformer
My wife uses your Probook 6460B, approx. 14 inch laptop, on the road a lot while I'm driving to and from the lake. It keeps blowing the fuse in our 07 Nissan Armada SUV. I got a Maxx 175 watt transformer thinking it was large enough to handle your laptop, but it must be so large that it blows the fuse too.
Any suggestions on what size transformer I can get/use without blowing the fuse for the passenger side 12v outlet?
She said she has been plugging it into the driver's side 12v outlet with no issues?
The only difference that I know of is driver's side always has power and her side/pax only has it when the key is on.
Previous Boats: 04 X7, 98 190, 96 205, Sylvan Deck
Thanks and best wishes, George & Sara Amonette
770 634 5437
[email protected]
Old 07-03-2013, 10:51 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
The transformer you picked out must a 17 amp or larger fused circuit. I am pretty sure it's a 15 amp fuse for the pass side cigar lighter, but I also think the drivers side also uses 15 amp fuse so I don't know why it doesn't also blow the fuse on the drivers side. You need at least a 20 amp circuit to safely operate your transformer. Typically with transformers it's a 100/10 ratio, so you would use a 150 watt max inverter safely on the armada's 15 amp circuit.
/spôrk/
Old 07-04-2013, 12:19 AM
Lars's Avatar
Lars Lars is offline
Boat: PS197
^ what he said, I thought most convenience outlets were actually 10 amps... If you're just using a laptop charger, that shouldn't be more than 100 watts (my macbook pro charger is 85 watts).
If it were me I'd check the wattage on the charger and get a transformer (inverter) that's rated a little more than that.
Old 07-04-2013, 12:53 AM
ProStar190Fan's Avatar
ProStar190Fan ProStar190Fan is offline
Boat: Looking for a PS190
Make sure the laptop is well under what the inverter is rated for. Since one of the outlets is keyed it may be at a lower amperage. Check the book to see exactly what each is fused at.
Tom
1988 ProStar 190 red/gray
-Ford 351
-OJ 13x11 prop
-Kenwood Stereo
Need a manual go here http://www.mastercraft.com/knowledge/owners_manuals/
Old 07-04-2013, 04:58 PM
88 PS190 88 PS190 is offline
With inverters it is a solid idea to hard wire it to your car if you use it much - adds the risk of not remembering to turn it off - but you open up the option of having the full capacity of the inverter.
I can even use an electric griddle on mine that way.
