Old 07-06-2013, 07:13 PM
LJN LJN is offline
Boat: Mastercraft, maristar 210, 2000
Originally Posted by bigmac View Post
http://www.bukh-bremen.de/files/346/...is%20ZF85A.pdf
Don't forget to address the corroded output shaft and be prepared that you may not be able to seat the new seals due to pitting of the seat.
Thank you!
If I am faced with this, do you think that a speedi-sleeve kit would be a propper way to address the problem?
Also, where is a good source for parts?
Thanks,
Luke
Old 07-06-2013, 07:26 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Originally Posted by LJN View Post
Thank you!
Thanks,
Luke
I think Engine Nut is 10x smarter than I am about Indmar drive trains. If I were you, I'd call Indmar. SkiDim is another good source for parts. Both places work hard to be helpful over the phone.
I don't know where you're going to find a service manual for the boat. AFAIK, they aren't available.
'04 MariStar 230VRS/MCX
Old 07-07-2013, 09:40 AM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
Thank you!
Thanks,
Luke
Th speedi-sleeve is the only way to address the issue. Replacing the entire hollow shaft that runs through the transmission is an extremely difficult an expensive job. There is a service manual for the transmission but it does not show the speedi-sleeve installation and tells you that you have to disassemble the transmission to replace the seal. You don't have to. The seal can be removed fron the outside. You can get the parts from inboardonline.com
The output shaft seal for the engine side is P/N 905214 and the speedi-sleeve kit is 905215. If they don't list them on their site, call them and they will get them for you.
Engine Nut
Indmar Marine Engines
Power to the Sport
Old 07-11-2013, 11:57 AM
LJN LJN is offline
Thank you both for the help & part #'s!
I'm trying to pull this apart before I order all of the parts. I just pulled the prop (great fun!), & now Iím about to disassemble the inner coupling. Before I mess anything up, is this the proper procedure? Can anyone give me a quick run-through of how it all comes apart? I have looked at the manual & nothing addresses this part of the removal.
Thanks again for everything,
Luke
[IMG][/IMG]
