Old 07-07-2013, 08:51 AM
amcmac's Avatar
amcmac amcmac is offline
Boat: X2
I ordered the bolt on replacement. I assume it it's DOT 3, but I was curious if anyone has used 4 or 5.
Old 07-17-2013, 10:30 PM
amcmac's Avatar
Boat: X2
I got my outer member painted and the inner assembly installed. I see what others have said about spinning the assembly on the brake line to prevent the line from twisting. Before I did that I prehung the assembly on the trailer frame and noticed an issue. On the old assembly the female port on the back of the reverse lockout cylinder is close to the pivot point of the coupler assembly. On the new coupler assembly the port is much further forward. I think I can get the flexible brake line to reach the port and screw in. My concern is that the line will already be stretched and taught that it won't be long enough to allow the coupler assembly to swing away. Am I missing something? Has anyone ran into situation?
Old 07-27-2013, 11:21 AM
OHpage21 OHpage21 is offline
Boat: MC, X9, 2006, RTP-1
How did you get your brake line attached? Do you remove the old adapter from the reliable one and attach it to the new UFP solenoid?
Old 07-29-2013, 07:04 AM
amcmac's Avatar
Boat: X2
I'm not sure what you mean by adapter.
